Help 1995 civic depressurze fuel?????
Old Dec 24, 2009 | 12:09 PM
EG-SIXV-TEC's Avatar
Post Help 1995 civic depressurze fuel?????
Hi im wanting to change out an old fuel filter of mines and will add a fuel gauge on the banjo bolt,
First of all how do you depressurize the fuel pressure the book says to take out a fuel pump fuse after running the engine and shut off I can't find the fuel pump fuse.
also remove the fuel cap???
how??? pls help..
Also i bought a fuel filter from Napa but i didn't install yet because the bottom bolt is longer than factory bolt. will the fitting fit i dont want to remove yet???
Old Dec 24, 2009 | 12:14 PM
bb4socal's Avatar
Default Re: Help 1995 civic depressurze fuel?????
honestly the easiest way is to take off fuel cap and just use rags over the fuel filter while removing the banjo bolt. thats how i do it at worK. the system really not under that much pressure.
Old Dec 24, 2009 | 01:15 PM
O okay thanks
Master23
Jun 23, 2009 05:23 PM
HASUNA91
Oct 22, 2007 04:33 PM
muggins
Oct 8, 2007 12:24 AM
ragejed
Jul 23, 2002 09:57 AM
Trigun
Mar 25, 2002 06:56 PM
