hey peeps hondalog dont log high cam
hey how is it going,names josh i have never posted anything on here never really had to . i have a 91 da with a gsr 12.5cp pistons eagles rods gsr head. i built and also wire tucked the beast and tune her .I have a p28 ecu with a p72 rom im using crome pro with the autoprom ,lm1 ,hondalog,and was using the tunertee but currently down!all the settings are good j12 is cut everything seems to work fine other than high cam doesnt log at all just low cam i am currently running threw the lm1 analog output cause the tunertee is down but even when it did work high cam still didnt log some one please help
It could be a few different things. Most common is electrical noise. Also the fact that you're using Crome and it uses a one byte response protocol. My advice, get something better... or track down whatever is causing the noise. Good luck.
Yeah dude, frankly, Hondalog = epic fail; you can't get reliable readings with it.
You'll spend more money on random crap trying to get it working than you will on a proprietary RTP package. Totally worth the investment.
The same ecu with a demon/s300 will drop logging all day long. It all comes down to electrical noise and interference, and most of the RTP boards are a lot more finicky when it comes to electrical noise and dropping logging.
Im starting to think it is the logger cause i had everything in another car different ecu and had the same problem both cars have the batterys in the hatch could this have anything to do with the ground noise even with the tunertee hooked up it wouldnt log high cam,then all of a sudden my tunertee started acting up so i havent used it in awhile suppose to send back to get looked at even tho Im working with cheap electronics and software how can i fix this cause im not the only one using this stuff its being done everyday
motoxxxman
Engine Management and Tuning
12
Oct 29, 2014 05:48 PM
