Timing belt drive pulley B18c1
Old Dec 21, 2009 | 09:29 PM
hmtcrxsir's Avatar
Default Timing belt drive pulley B18c1
I just have a quick question regarding the timing belt drive pulley for my B18c1. My question is since there is a slot for the key on the timing belt drive pulley. Is there suppose to be a key that is place between the slot of the timing belt belt drive pulley? Or does the key only meant for the crankshaft drive pulley? Im just kinda confused because the timing belt belt drive pulley has a slot for a key. Anyone know what im talking about?according to the Helms manual. It shows that the key only goes to the crank pulley and not the timing belt drive pulley. am i correct? but it looks like there suppose to be a key there as well because there is a slot for it.
Old Dec 21, 2009 | 09:35 PM
Brad's Avatar
Default Re: Timing belt drive pulley B18c1
I believe the timing belt drive pulley has a built in key.
Old Dec 21, 2009 | 09:38 PM
hmtcrxsir's Avatar
Not the B18c1.Only the B18A/B has a built in key.
hmtcrxsir's Avatar
Im not talking about just the Crank Pulley itself. I know that the crank pulley needs a key. Im talking about the Timing belt drive pulley that holds the timing belt in place that is on the crank itself. According to Helms manual there is no key for the timing belt drive pulley. But there is a slot for the timing belt drive pulley. They are two seperate parts. I repeat im not talking about the Crank pulley but the timing belt drive pulley. Look below for a picture.
You see how there is a slot for the key? Is there suppose to be a key there for the timing belt drive pulley.
Old Dec 22, 2009 | 08:41 AM
IN VTEC's Avatar
The key is one piece with the sprocket.
Old Dec 22, 2009 | 10:19 AM
hmtcrxsir's Avatar
how come the B18c1 Sprocket is different and is empty rather than built in?
Old Dec 22, 2009 | 10:21 AM
hmtcrxsir's Avatar
There is no key in this GSR Sprocket.
crvglenn
Honda CR-V & Element
Aug 20, 2017 01:44 AM
hmtcrxsir
18
Dec 6, 2014 03:17 AM
us31wking
Aug 21, 2014 04:50 AM
Vtran4600
Jun 22, 2009 08:54 PM
DocSean
Jan 16, 2006 09:20 PM
