Pulled E brake too hard and now left rear drum is stuck
Old Dec 21, 2009 | 09:20 AM
AlphaKennyWun's Avatar
Default Pulled E brake too hard and now left rear drum is stuck
Happened overnight while I had the E brake on. I might have pulled up on it too hard. Its also been raining and cold. Now the drum and subsequent wheel does not spin. Usually I can drive in reverse and it will pop and come unstuck. Not this time. Ive tried hitting the drum with a hammer, driving the car back and forth. Any other ideas? Apply heat to drum with a Blow torch ?
Old Dec 21, 2009 | 09:21 AM
kaiba's Avatar
Default Re: Pulled E brake too hard and now left rear drum is stuck
LOL. This brings back some memories.
Remove your rims. Used a hammer and hit the drum until it's free.
Originally Posted by AlphaKennyWun
Happened overnight and when I had the E brake on. Might have pulled up on it too hard. Its also been raining and cold. Now the drum and subsequent wheel does not spin. Usually I can reverse some what and comes unstuck. Not this time. Ive tried hitting the drum with a hammer, driving the car back and forth Any other ideas? Apply heat with a Blow torch it?
Old Dec 21, 2009 | 09:31 AM
EFWhite's Avatar
I was thinking heat and a hammer might do the trick assuming it's temperature related, worse comes to worse you might have to pull the drum apart...
Old Dec 21, 2009 | 09:36 AM
hermistonkilla's Avatar
i had my e brake freeze once in my integra! just put a light underneath it and an hour later it was free!
Old Dec 21, 2009 | 09:40 AM
hatchet_honda's Avatar
a light??? mustve been pretty warm out still...
Old Dec 21, 2009 | 09:52 AM
motoman110's Avatar
Could be the parking brake cable froze too, happens here in MN. Moisture gets in the cable while driving during the day and as it sits over night it can freeze. Thats why I tend to not use my parking brake during the winter months
I just noticed your location haha so your cable is prolly not frozen, but still throwin it out there
Old Dec 21, 2009 | 10:27 AM
lol sorry it was a flood light! used the same light to thaw out a 351
Old Dec 22, 2009 | 04:59 AM
I took off the tire and struck the drum with a hammer. It came unstuck in about three strikes.
I think its just rust and dirt inside the drum. Would it be a waste of time to take the drum off and spray everything minus the shoes with a penetrant like brake clean?
Old Dec 22, 2009 | 05:42 AM
88Hatchy's Avatar
Brake parts cleaner isn't a penetrant, you can spray the whole assembly with it.
Old Dec 22, 2009 | 06:23 AM
SIred91's Avatar
Rainman
Most deffinately take it apart and spray everything with parts cleaner
Old Dec 22, 2009 | 09:39 AM
yeaa...doods in miami. def not frozen lol. id say theres **** in the drum pinned inbetween ****. brake cleaner!
street_ride14
Sep 3, 2011 08:35 AM
MrDomino
May 15, 2008 03:42 PM
globy123
Aug 15, 2007 05:27 PM
george34
Feb 4, 2006 06:01 PM
thenick
Nov 12, 2002 07:50 PM
