D16B2??
alright, ive been looking around, but i cant find to bunch info on this motor. its a D16B2, from a European CRX. my friend has one in his garage he's rebuilding, and im curious of the specs on it. i read somewhere its simular to the y7. is this true?
also, he's going to use a D16A6 head he has on top of it. is this a good head as compared to some?
you didnt really search now did you? literally withing 10 seconds i found this....
http://www.club-honda.eu/engine_detail.php?id=72
Manufacturer code: D16B2 (1.6}
Year of production::
Fuel: gasoline
Fuel preparation: Multi-point fuel injection (MPFI)
Supercharging:
Camming: OHC
Cubic capacity: 1590
No. of cylinders / Arrangement: 4 / In-Line
Valves no.: 16
Compression ration:
Performance [kW] / RPM: 85 (116 PS) @ 6300
Torque [Nm] / RPM:
Bore x Stroke [mm]:
Note
Fuel: gasoline
Supercharging:
Camming: OHC
Valves no.: 16
Compression ration:
Torque [Nm] / RPM:
Bore x Stroke [mm]:
Note
I was hoping maybe someone with some experience with this motor would chime in. I did search. But none of the info was substantial. Now, is the a6 head a good one? And is the d16b2 block similar to the y7?
that the first thing i would look for, y7 dipsticks come out a the side of the engine.
the y7 head has 1mm bigger intake valves than the a6, and that's a good thing. but the a6/b2/b7 (all the same casting) head all have much more aftermarket support as far as camshafts and and things like that go.
I have one of these, and turbocharged it. They are pure Honda and usually from auto's in M series Civics built in Swindon for UK and Europe. Some engines may have been sold to Rover (Honda owned part of Rover). Most differences to other D's are with the ancilliaries like the distributor and intake, Different ECU and wiring too.
I have a d16b2 in my 92 hatch im currently in germany but i cant find any parts for it or any information either. Also mine is dpif I dont know what kind of performance parts to put on it or which way to go about it.
I don't know how this motor has ended up in a 92 hatch though. Mine is a 98 and I know these motors were in some other 96+ MB Civics, usually auto's. Does yours have a plastic intake manifold?
still on stock internals, T3 .42/.48 @9psi tuned on a p06 with Crome. I must mention that it's also an auto
I got my intake manifold & throttle-body from a local dismantler. The exhaust manifold, downpipe, turbo, wastegate, intercooler & piping, distributor,fuel pressure regulator, gauges & pod, boost controller, and catch can were from different sellers on ebay.
The socketed ECU, LC-1 wideband O2 sensor, Moates Ostrich RTP, Precision 440cc injectors and fuel pump were all from Xenocron.com in the US. Wiring was done by myself and the 2.5" stainless exhaust was hand built locally.
I've got a couple of complete A6 manifolds if you can't find one locally.
Also, there is a Honda Database app available through the Google Play store for Android phones. It's been a good resource and it is updated quite often.
Tuner Eddy
Aug 16, 2005 11:08 AM
