D16Z6 Turbo Build Parts List Help
Hello guys, I am building a D16Z6 into my 2000 Civic DX and I want to know what I'm missing from the list of parts I already purchased and if it will make 300whp at least after tune.
Eagle Rods
Nippon Vitara Pistons
OBD1 Conversion Harness
BLOX Racing Boost Gauge
Phearable.net boost controller
4 Bar Phearable.net Map sensor
ChromePro Chipped P28
AEM Wideband
450cc injectors
ARP headstuds
255lph Fuel Pump
Oil Pressure guage
AEM Fuel Pressure Regulator
Clutchmasters clutch and Flywheel
VW GLI Stock Diverter Valve
Big Intercooler 12X36X3
3" downpipe, 2.5 inch full exhaust
Garrett T3 Super60 Turbo
About what PSI will I need to produce that much power and what else am I still missing? Thanks
Eagle Rods
AEM Wideband
450cc injectors
ARP headstuds
255lph Fuel Pump
Oil Pressure guage
Im getting OEM rods bearings.. just have to plastiguage the old bearings first and see how much the clearance is. and you think the OEM z6 headgasket is the best for turbo? will advance auto gasket work?
bigger injectors than DSMs also. You should look at 750+ for those goals so you have roon to grow should you want. I use fel pro gaskets in my motors but i dont boost. But i know plenty of people who do and use them and they are just fine
I want the smallest injectors possible for 300hp with 80% duty cycle so my idle runs perfectly fine and still starts in the colder weather, so thats pretty much all the parts I need? Im not missing anything?
DelSolDon
May 22, 2007 10:54 AM
