Injector question E85
Old Dec 19, 2009 | 01:42 PM
CivSiClone_96's Avatar
Default Injector question E85
Hey building a LSvtec im going to be running E85 on it i need to know what injectors can I run with a resistor box for E85??? i know i need 1000cc or higher for E85 but I have a resistor box. Thanks for your time.
Old Dec 19, 2009 | 03:44 PM
mr.danny's Avatar
Default Re: Injector question E85
search.
Old Dec 19, 2009 | 05:31 PM
SPOOLINmatt's Avatar
rc 1000's 1200's 1600's
precision 1600's(with an injector driver preferably)
Injector dynamics 1000 and 2000cc, no need for resistor box.
This isnt a hard issue.
Old Dec 20, 2009 | 01:47 PM
ya i understand that i guess i was trying to ask that if using a resistor box would limit what injectors i could use for E85?.
Old Dec 20, 2009 | 02:04 PM
jeffnerette's Avatar
No. It's on the contrary. If you're not using a resistor box then it limits the injectors you can use. Most high flowing injectors are low impedence(peak and hold) aka need a resistor. But I personally would not run the resistor and get the ID1000's they are amazing.
Old Dec 20, 2009 | 02:16 PM
what is the power goal?
Old Dec 20, 2009 | 05:28 PM
my power goal is 400whp on a LSvtec with ITR cams and a good turbo setup I got for it. I should beable to hit that on E85 prolly going to run 1000cc injectors was thinking RC injectors.
Old Dec 20, 2009 | 05:52 PM
gringotegra's Avatar
you dont need 1000's to reach that goal but you can get them..if your goal is only 400whp then im sure some 880's would be just fine for you... i made 440 whp on E85 with 880's, they were about maxxed out though
Steeve_Civic
Dec 4, 2011 10:11 AM
lowtegsr
Jan 14, 2008 01:25 PM
deucedeuceEK
Oct 30, 2007 04:35 PM
NuclearB18B
Jul 10, 2003 05:59 PM
2K_TEG
Jun 2, 2002 09:28 PM
