are b16 & gsr dizzys the same? what internals are interchangable with an obd2 gsr?
i have a obd2 gsr dizzy that took a crap on me and i'm lookin to replace it with an used one. what i want to know is if a complete b16 dizzy will bolt up to a gsr head because i know the cap is different between the 2.
i also would like to know what dizzy internals(coil/ignitor) are interchangable with a obd2 gsr dizzy like obd1/obd2-ls/b16/gsr?
thanks in advance.
thanks in advance.
thanks in advance.
thanks in advance.
yes any complete obd2 vtec dizzy will work. as you have already discovered the caps are different depending if you have td-81, 84, 86, 87. not sure about the internals, they show different part #'s but may be interchangeable.
