what is the max boost recommended for a stock 95 b18b...?
Old Sep 3, 2002 | 07:50 AM
soontohavecrx's Avatar
Default what is the max boost recommended for a stock 95 b18b...?
also do turbo kits come with EVERTHING you need. like new injectors and fuel pump, etc...?
Old Sep 3, 2002 | 10:10 AM
AlterEgo's Avatar
Default Re: what is the max boost recommended for a stock 95 b18b...? (soontohavecrx)
The Greddy kit comes with a set of injectors and some type of crappy fuel management.
Most turbo kits don't come with the proper fuel components like the injectos, pump, FPR, EGt...ect... The normally only come with the hardware for the turbo, piping, oil...etc...
Old Sep 3, 2002 | 11:29 AM
hybrid901's Avatar
Default Re: what is the max boost recommended for a stock 95 b18b...? (AlterEgo)
Depends on your fuel managment. With a FMU 8-9psi and with a hondata 10-12 psi.
Old Sep 3, 2002 | 12:39 PM
SIK IN DA HED's Avatar
New User
Default Re: what is the max boost recommended for a stock 95 b18b...? (hybrid901)
DRAG3 kits come with everything you need. BUT... i would upgrade the oil return line with stainless steel lines instead of the metal pipe and rubber hose.
Old Sep 5, 2002 | 08:08 PM
Danger's Avatar
Default Re: what is the max boost recommended for a stock 95 b18b...? (dlplayboy)
upgrade ur injectors , get a apex SAFC , and also a boost controller . you should be safe around 12lbs . depending on how many miles you have and how often you will be mashing it .
Old Sep 6, 2002 | 07:50 AM
311's Avatar
311
if you are thinking of getting an LS turbo kit, go here https://honda-tech.com/zerothread?id=269507
Old Sep 6, 2002 | 08:44 AM
fuguman's Avatar
New User
http://www.tooez.com/turbo/
93da9kid
Jan 30, 2011 07:08 AM
V8Hunters
May 2, 2006 07:07 AM
94hybridcoupe
Apr 6, 2005 06:53 AM
TANDT
Jan 19, 2004 07:14 PM
fuguman
Apr 19, 2002 10:50 AM
