CR-Vtec
Old Sep 3, 2002 | 07:50 AM
Bullet50's Avatar
Default CR-Vtec
Question for the board...........
I was pretty much set on installing a boosted B20B but after doing some reading and limited price checking I was considering going N/A with a CR-Vtec (B20/B16). I've got the block and Transmission for the swap. What I need to know is "What else is required in addition to that to do a sucessful swap?"
Thanks in advance for the help.
B50
Old Sep 3, 2002 | 08:20 AM
BROOD's Avatar
Default Re: CR-Vtec (Bullet50)
B50
B50 life.....heh heh, diesel speak
CRVtec man it is covered so many times (sorry but here it comes ) do alittle searching. You will come up with some more specific questions which are more likely to get responses from others. Try searching under the archived files using: LSVT, LSVtec, CRVtec, frankenstein, oil feed lines, P28 ecus, LS connecting rods, LS rod bolts, main girdle, Vtec water pump, Vtec oil pump, "goes on and on". Read through some of that info and you should be pretty well set.
Good luck on your CRVtec project
Old Sep 3, 2002 | 11:41 AM
Bullet50's Avatar
Default Re: CR-Vtec (SLPR)
Thanks SPLR.................... I'm on the hunt. Just need to know where to look.
B50
Old Sep 3, 2002 | 04:23 PM
tinkerbell's Avatar
https://honda-tech.com/zerosearch
"crvtec" "b20vtec" "b20b + vtec"
EDIT: make sure you check the archives!!!
hth,
t..
[Modified by tinkerbell, 11:24 AM 9/4/2002]
Old Sep 4, 2002 | 03:09 AM
Bullet50's Avatar
Default Re: CR-Vtec (tinkerbell)
Thanks T.................. I'm on it.
B50
delorean
Apr 22, 2011 03:40 PM
DC2fab
Jan 16, 2010 01:37 PM
blacc_ej1
27
Aug 10, 2009 08:31 AM
The Si
11
Feb 13, 2007 01:34 PM
testingcheck
Aug 14, 2005 10:50 AM
