AVC-R/Tial Highpressure Vacuum Lines question!
Old Sep 3, 2002 | 06:49 AM
BlwnBlue's Avatar
Default AVC-R/Tial Highpressure Vacuum Lines question!
I just got a tial highpressue wastegate..I hooked it up just like my deltagate used to be and I don't start to boost till 5000-5500 rpm's..WTF? Car is a B18C w/ Cometic headgasket lowing compression to 9:1..only boosting 5-6psi...don't wanna mess anything up because vacuums might be wrong...but I had a built b16 in there(9:1 as well) and I was boostin by 4000rpms...so i'd figure the b18c would spool the turbo even faster..
right now vacuum lines come from the solenoid of the avcr to the tial as follows:
(no) plugs into side of tial and is 'T'd to the comressor of the turbo..just like the instructions say
(com) plugs striaght into the the top of the wastegate..
(no) has nothing in it
some other things..it sounds as if the wastgate is always open anytime I step on the gas(boost or not) ..I sound like I running open exhaust ..I thought the tial wasn't supposed to open til it got to the desired boost level..then opens..
I tried searching but I guess I didn't use the "right" key words to find anything useful in my search..
Old Sep 3, 2002 | 07:40 AM
Dee's Avatar
Dee
Default Re: AVC-R/Tial Highpressure Vacuum Lines question! (BlwnBlue)
-4 line is used to connect the solenoid to the top of the HKS wastegate and to the vacuum/boost signal on the IC piping while a -6 line connects the bottom W/G port on the IC piping.
[IMG][/IMG]
Old Sep 3, 2002 | 08:26 AM
BlwnBlue's Avatar
Default Re: AVC-R/Tial Highpressure Vacuum Lines question! (Dee)
If I'm reading it correctly, I think that is the way I already have it? or do you not have anything running to the turbo..I think your I/C piping is the equivelant to my "t"ing off the turbo though..
Anyone else out there that can help?
Old Sep 3, 2002 | 08:29 AM
Dee's Avatar
Dee
There are 2 tapped sources on the IC piping less than 12" from the compressor housing! -4 for the AVC-R solenoid and a -6 for the bottom w/g port!
Old Sep 3, 2002 | 08:39 AM
BlwnBlue's Avatar
when does your car start to boost? Is the wastegate open always, even under normal driving..
I've recently changed back to open loop from closed loop..I don't recall my deltagate always being open..
Old Sep 3, 2002 | 08:43 AM
Dee's Avatar
Dee
My w/g doesn't open until I hit the desired level of .7bar.
Old Sep 3, 2002 | 08:52 AM
BlwnBlue's Avatar
well thanks alot ...
I just can't see why it would make that much of a difference going from my deltagate to the tial..
and everyone always says the tial is better than the deltagate..however I never had any probs like this w/ the deltagate...
I don't really want to plumb my IC piping seeing as how I've never had to run it like that before..
how do the rest of the people on this board have theirs setup..
[Modified by BlwnBlue, 12:21 PM 9/3/2002]
Old Sep 3, 2002 | 10:21 AM
Ri5e's Avatar
You did a USDM Conversion on a JDM Integra?
Old Sep 3, 2002 | 11:44 AM
BlwnBlue's Avatar
Default Re: AVC-R/Tial Highpressure Vacuum Lines question! (CRV Monster)
ttt
anybody?
Old Sep 3, 2002 | 01:31 PM
BlwnBlue's Avatar
105 looks but no help..
can someone please tell me how they have their avc-r's vacuumed to the tial...
flangemastermike
Nov 7, 2008 04:27 AM
ef dino
Sep 16, 2007 10:21 PM
blu_si
Oct 1, 2002 04:20 PM
