clutch engagement issue/GSR swap
Old Dec 18, 2009 | 06:04 AM
TheSickestDC2's Avatar
Default clutch engagement issue/GSR swap
I just installed the swap and everything started up fine. The first time I went to take off from 1st, tires spun (not familiar with brand new clutch haha). After that, the clutch would not engage on any gear, i tried taking off from first and second and nothing happened. I can put it in and out of gear with the car running without the clutch engaged. I bled the clutch line numerous times and it is fine. Any ideas?
Thanks ahead
Kyle
Old Dec 18, 2009 | 06:11 AM
red_crx's Avatar
Default Re: clutch engagement issue/GSR swap
So the car wont go into gear while the motor is running, while pushing the clutch in?
Old Dec 18, 2009 | 09:42 AM
no it goes in gear while the car is running but i dont have to put the clutch in to put it in gear and it doesnt grind just goes in smoothly
Old Dec 18, 2009 | 01:22 PM
98GSRrdr's Avatar
Ok just to be clear... You can start your car... and shift it into gear without useing your clutch ... Does the car take off when you put it into gear without the clutch ? If no ... then your not in gear ? Somthing has to be broken ... take the clutch back out and see whats up..
Old Dec 18, 2009 | 06:26 PM
yeah you got it right dude but it goes in gear for sure
Old Dec 20, 2009 | 06:44 PM
hahaha i'm dumb when i looked over everything after putting the swap in i overlooked the passenger side axle wasnt in all the way, so bingo that was the problem as simple as that thanks everybody for all the info.....thanks to Rukusmasta2
will rockit
May 7, 2015 08:00 PM
SynSterLove
Sep 29, 2012 03:17 PM
bb4socal
Dec 20, 2005 12:13 PM
binkster
Jan 29, 2003 02:17 PM
NickGSR
Sep 15, 2002 05:26 PM
