Suspension & Brakes Theory, alignment, spring rates....
Koni GS vs Progress differences
Old Dec 17, 2009 | 03:00 PM
GagnarTheUnruly's Avatar
Default Koni GS vs Progress differences
This summer I'm going to be replacing all of my suspension bushings because they're all blown. I thought it would be a good time to add an ITR on ASR swaybar, and I've been toying with the idea of getting new shocks/springs as well.
I talked myself into Koni GC, but this Progress promotion worked and drew my attention to those coilovers. I'm interested in a suspension that will still ride well but that will roll less and turn in better than stock. I'm thinking 350/250 rates and about a 1" drop only (MT roads are not the best always). Conveniently, those rates are easy to get with both setups. These will be paired with ITR rear swaybar and 195/55/15 S.drives on a 96 GS-R coupe.
My questions:
How does the ride compare between Koni GC and Progress with the above spring rates?
Would I need front tophats for a 1" drop for either setup?
How much of an advantage is the damping adjustability on the Konis?
Is it true that the Konis have a lifetime warranty vs. the Progress?
I'm trying to decide whether Koni GC is worth the extra $350-400. Edit: I forgot to add that this is DD only and must be wife-approved.
Old Dec 18, 2009 | 12:02 PM
Default Re: Koni GS vs Progress differences
bump
Old Dec 18, 2009 | 05:27 PM
jdm em2's Avatar
I really dont no about koni, but i have a 2005 civic and i have full progress coils on my car and i have the stock springs that come with it probably after the new year iam going to by my new spring rates really haven't decided yet on which rate. But i love the ride a little cost mine was 1,000 shipped, then a old freind of mine did my back strut towers (extended them) and they helped a big diffrence.
Progress are also alot cheaper IMO to fix wise as for ex: if u blow a strut they u can send the blown one back and if im not mistaken its like 75$ for a new one (dont mark my work) as for the top hats u can buy the k-sport top hats i heard they work wonders as for ride quailty and adjust ur camber and what not.
Old Dec 18, 2009 | 07:08 PM
koratb's Avatar
koni are lifetime warranty have that in my acura TL ..progress group is pretty decent they have 2 version of them ride pretty decent quality is there i just went with another route to PIC select coilover and im loving it really cant say more bout that
Old Dec 18, 2009 | 07:14 PM
katzenjammer84's Avatar
Progress will provide better ride quality, as it's not as stiff. The trade off is you won't handle as well as somebody on Koni/GC's. This is somewhat spring rate dependent, but IMO Koni makes a superior damper. I'm using my opinions based on driving two different DC2's with these setups.
Both seem to be reliable, I haven't heard of any early blowouts with Progress yet.
Koni's don't like to be particularly low, so if you're hellbent on more than a 2.25"+ drop I'd get Progress, unless you can find extended top hats for your application.
Old Dec 18, 2009 | 07:19 PM
I'm probably going to run the minimum drop on each setup. The Progress I'm looking at are around $550, which is a lot cheaper than I can get Koni/GC for. Is the ride quality on the Progress definitely better than Koni/GC. That's an issue for this DD.
Old Dec 18, 2009 | 07:23 PM
STOCK_SOHC_DX's Avatar
Koni SP (I have no idea what GS's are) = lifetime warranty and height + rebound adjustable.
Progress = 1yr warranty and height adjustable.
Old Dec 18, 2009 | 07:25 PM
The warranty is an issue, too. I like the idea of never having to buy a new shock again for my car.
Old Dec 18, 2009 | 07:32 PM
This is only an issue if you are going to keep your car for a while. Honestly I have had Progress way back when they went for $1000 a set and those lasted for about 10yrs. I'd say they were worth the $$. Only reason why I know how long they lasted because I sold them to a buddy and he sold them to another guy that I know.
Old Dec 19, 2009 | 03:55 AM
92civiceg9gsr's Avatar
I say progress is great having had both setups. Koni/GC/GC tophats and Progress Series 2 coilovers
m!ke
Suspension & Brakes
Jun 24, 2011 04:45 PM
DC206R
Suspension & Brakes
137
Jun 16, 2011 04:44 PM
VTecLude1994
Suspension & Brakes
Jan 26, 2011 01:04 PM
egb18c5
Suspension & Brakes
Dec 26, 2006 06:14 AM
JSTOCK
22
Nov 1, 2001 11:59 PM
