I need some info on diameter of ls/b16/gsr crank journals.
Old Dec 16, 2009 | 07:51 PM
GSR_hatch936's Avatar
Default I need some info on diameter of ls/b16/gsr crank journals.
Like the titles says if anyone has a print out sheet with the main journals and rod journals for these motors I would really like this info.! Thanks in advance.
I tried this in a different section and didnt get any respond.. So anyone with this info please chime in!! or direct me to a better direction where i could find this information.
Old Dec 17, 2009 | 12:19 PM
Default Re: I need some info on diameter of ls/b16/gsr crank journals.
I need his info asap!
Old Dec 17, 2009 | 12:53 PM
PrecisionPerformanceParts's Avatar
http://www.aclperformance.com.au/us/...rings_crus.htm
Click on the bearings for the motor you want and it will tell you the min and max crank journal sizes.
Old Dec 17, 2009 | 05:12 PM
Thanks sooo much bro
Old Dec 17, 2009 | 05:50 PM
One more question,,, is tha the inside diameter of the bearings or the outside diameter of the journals?..
Old Dec 17, 2009 | 08:50 PM
Acura/Honda B16A2, B16A3, B17A1, B18A1, B18B1, B20B, B20Z Engine Bearings
YOU ARE HERE: ENGINES/VEHICLES > HONDA >B16A2/B16A3 B17A1 B18A1*B18B1 B20B B20Z > ENGINE BEARINGS
*ENGINE BEARINGS
CON ROD BEARING SET
MAIN BEARING SET
Part# Part#
4B1946H
4B1946HX
* 5M1959H
* 5M1959HX
Sizes STD, 025, .25 STD STD, 025, .25 STD
Oil Clearance Standard + 0.001" Extra Standard + 0.001" Extra
Half Type Identical Halves Upper & Lower
Material
Tri-metal Hardened steel backs
Tri-Metal
Min Std Shaft Size
1.7709" / 44.980mm
2.1646" / 54.980mm
Max Std Shaft Size
1.7717" / 45.000mm
2.1654" / 55.000mm
Min Std Tunnel Size
1.8898" / 48.000mm
2.3228" / 59.000mm
Max Std Tunnel Size
1.8907" / 48.024mm
2.3236" / 59.020mm
Max Wall at Crown
0.0592" / 1.504mm
0.0587" /1.491mm
0.0790" / 2.007mm
0.0785" /1.994mm
Max Overall Length
0.768" / 19.50mm
0.787" / 20.00mm
Old Dec 18, 2009 | 07:03 AM
Shaft size is the crank size, just like you would measure with a micrometer on the journal.
Old Dec 18, 2009 | 07:34 AM
pettyboy69's Avatar
next time post this in the right section, crank journals have nothing to do with forced induction and if you post in the right section you will get info faster.
Old Dec 18, 2009 | 09:10 AM
Ok I guess reading owns you and yes I did post in the right section at first but got no respond as I posted above so if you got no input about what the title say Gtfo! Damn why do ppl wanna act like moderators on fourms?!!!
sanjay2
Jun 14, 2010 07:21 AM
acrocat
Jun 15, 2007 06:34 AM
VtecnTurbo
Oct 8, 2006 07:16 AM
super laubo
Mar 24, 2003 03:15 PM
TheSwift1
Nov 12, 2002 08:12 AM
