tranmitton seperation!!??
Old Sep 3, 2002 | 01:54 AM
madhatch's Avatar
Default tranmitton seperation!!??
I took the engine out and it is in good shape, a little corrosion around some areas. We took all the bolts out but cant seem to seperate the tranny from the motor. I was wondering if anybody had some advice. I want to use the tranny on my motor, I need some help.
Old Sep 4, 2002 | 09:11 PM
madhatch's Avatar
Default Re: tranmitton seperation!!?? (madhatch)
any body ???
Hello????
Old Sep 4, 2002 | 09:17 PM
nikoniko's Avatar
try taking a ruber hammer to it around the seem to lose'n it up.
Old Sep 5, 2002 | 11:19 PM
Kamin's Avatar
Default Re: tranmitton seperation!!?? (nikoniko)
dont forget the starter bolts
if all else fails get a probay (but be carefull)
the tranny is a PITA to yank off.
Old Sep 6, 2002 | 02:12 AM
madhatch's Avatar
Default Re: tranmitton seperation!!?? (KAMiN)
I ahve the starter bolts out, and yes, suprisingly it is a real mother f#$er to take off!
Old Sep 6, 2002 | 04:25 AM
owen_the_soyboy's Avatar
if all of fthe bolts are indeed out, you need to slip a prybar/crowbar/BFscrewdriver inbetweena spot near the front of the block where you can get in there to wiggle them apart using the prybar/etc.
be gentle and have patience (to a point) because there are guide pins/dowel pins that hold th etranny in perfect alignment and force the tranny to be taken off without twisting it, or like it wont work if you try to remove one side first..
Old Sep 8, 2002 | 05:08 PM
madhatch's Avatar
Default Re: tranmitton seperation!!?? (owen_the_soyboy)
thanks every body, I got it, it took a prybar, a 2x4 a hammer some wd 40 a scraper and two friends. Biatch I guess the car was in michagan for a while. It had some corrosion. But it looks great now
navin
Mar 26, 2019 11:14 AM
Ej1_coupe
May 17, 2005 08:37 PM
luti
Nov 29, 2004 11:52 AM
Unjockable
20
Nov 10, 2003 02:36 PM
navin
Mar 18, 2002 11:28 AM
