Car horn intermittently working.
Old Dec 16, 2009 | 07:24 AM
arielb1's Avatar
Default Car horn intermittently working.
I've searched the forums for "horn" with no luck.
My horn is intermitently working. Sometimes it just does not work. Other times, it works at the slightest touch. Not sure if I am searching correctly.
Anyone have a clue for where I should start?
1998 Honda Accord Sedan 123K miles
Many thanks
Old Dec 16, 2009 | 09:19 AM
uberEFtuner's Avatar
Default Re: Car horn intermittently working.
hook up a multimeter to the horn wires and see if there is voltage when you push the button. If so you have a bad horn. They are cheap
Old Apr 13, 2012 | 08:19 PM
arielb1's Avatar
update, I swapped the horn relay with the lightning relay. No problem since. Apparently, the relay was on it's way out. The relay is located in the engine area near the firewall on the driver side..
Old Apr 13, 2012 | 08:32 PM
dglassmyer's Avatar
Did it take you three years to fix your horn!!??
Old Apr 14, 2012 | 07:42 AM
arielb1's Avatar
No, I fixed it shortly after I posted my question. When I did a search on my past postings, I noticed I left this topic open. I hate reading post and the problem is not solved when I am searching for answers. I'm just trying to set an example for other to follow up with post when possible.
Old Apr 14, 2012 | 08:59 AM
dglassmyer's Avatar
I kinda figured that was the case, just goofing around with you really
Old Sep 23, 2014 | 01:37 PM
361 accord's Avatar
well, i guess all i can do is try a new relay, mine does the same thing
the only strange part is that it always works with the keyless remote, and i honk at people pretty much every day. so thats why i thought the horn switch itself could be worn out or need cleaning
if i keep trying the horn, eventually it works
Old Oct 7, 2014 | 04:49 AM
361 accord's Avatar
still nothing?
arielb1
Mar 7, 2010 07:38 AM
IOwNaHoNdA
Mar 9, 2009 08:21 PM
tianporn
Mar 15, 2007 03:23 AM
sattley420
Apr 26, 2006 07:44 PM
jacobpel
Jul 28, 2004 03:01 PM
