Starting problems
Old Jul 28, 2004 | 07:09 AM
jacobpel's Avatar
Default Starting problems
Hi,
I'm having a start up problem. It has been happening like every 5 days, I'll drive my Accord and have no problems, but sometimes when stop the and start it backup the engine won't turn over. The only "working" remedy is to release the pressure in the gas tank... is this a rochester vavle problem or something completley different?
I own a '90 Accord LX
Thanks,
~Jake
Old Jul 28, 2004 | 10:55 AM
brads94accord's Avatar
it is most likely your main relay. i would remove it and see if the contacts inside are corroded. it should be right next to your steering column under the driver side dash. get a haynes or helms manual and it should tell you exactly where it is.
Old Jul 28, 2004 | 03:01 PM
dockersguy's Avatar
Default Re: Starting problems (jacobpel)
Do a search on the forums or google and you'll find loads of information on the main relay. The problem lies with the solder joints becoming too hot and cracking making a poor connection. The problem can be fixed by buying a new main relay or re-soldering the solder joints. I recommend re-soldering the solder joints (cheap). This main relay problem is well known with this generation of Accords. Good luck.
vietxdragon
Mar 31, 2006 09:30 PM
RLOWE
Aug 1, 2004 10:30 AM
Shambro84
Mar 25, 2004 04:48 PM
fe519
Sep 17, 2003 04:34 AM
