clutch pedal adjustment issues
Old Dec 15, 2009 | 08:25 PM
DulinDragons's Avatar
Default clutch pedal adjustment issues
ok, i just replaced my clutch, slave cylinder and master cylinder. The system has been bled out atleast 6 times so far. The clutch wouldnt engage while the motor was on, i'd get a scratching sound when i wud push the clutch pedal in. I then turned the master cylinder rod on the pedal clock wise inward. I kept trying it untill the scratching sound went away. Now with the adjusting **** half way down the cylinder rod the scratch noise goes away and it can go into gear.
The bad part is the when i let off the clutch to give it gas, i hear a slight scratching noise. I'm starting to wonder if the master cylinder is defective or wrong size for the car and motor. its in a 93 civic with civic master cylinder and B18C1 engine.
Old Dec 16, 2009 | 09:42 AM
Default Re: clutch pedal adjustment issues
anyone?
Old Dec 16, 2009 | 11:08 AM
mouab18c1's Avatar
did you install the clutch properly?
Old Dec 17, 2009 | 06:50 PM
JNocon's Avatar
x2. Did you do a criss-cross pattern. Or maybe your clutch slave cylinder is not pushing the clutch fork properly. I think you should trace back what and how you installed your clutch.
gooblinn258
Jan 18, 2014 05:02 PM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
puertoroc7976
Sep 7, 2006 03:06 PM
integra3586
Oct 30, 2005 09:20 PM
bambbrose
Jul 6, 2005 12:46 PM
