94 Accord - Loud Squeek When turning
I have a 94 Accord, and when driving it's almost like your on a squeeky bed, it's always there when turning either way, but also squeeks when hitting bumps.
The squeek is coming from the passenger side (right) and my thoughts are lower or upper ball joint.
I hit the upper and lower with liquid wrench and it goes away for a few days, but seems to come back. My friend suggests the coil spring could be out of position or winding.
Would replacing the upper and lower balljoint be a good idea? or should I find out 100% where its coming from?
Thanks in advance,
Nick
Thanks in advance,
Nick
In most cases, a squeaking/creaking while turning the steering wheel is from the lower ball joint. Have someone else turn the wheel back and forth while you crouch beside the wheel and listen for the noise.
Hey Nick, psst, wrong forum https://honda-tech.com/forums/forumdisplay.php?f=2
heatwave
May 7, 2021 01:29 PM
