hydro locked
ok when i put the d16z6 in i was an idiot and tried to wire up the d16 dizzy. well i think i hooked up a wrong wire which always kept the injector flowing. now my car wont turn over. i think i hydro locked it with fuel. any ways to fix that???
its impossible to hydrolock a motor on pump gas, at the most, it wouldnt start, but it would still turn over. do you hear the main relay kick on when you turn the key to the accessory postition? see if your ECU is throwing any codes. you might have:
blew a fuse when you did the wiring.
fried the starter.
fried the starter.
take out all your plugs and try to spin over the motor. it will blow it all out the plug holes. and yes, you can hydrolock a motor on pump fuel.
Brennidon
Apr 19, 2012 05:10 AM
Civic_07
Apr 5, 2008 06:25 PM
