fog light problem rsx
Old Dec 13, 2009 | 04:47 PM
TeeHee's Avatar
Default fog light problem rsx
I search and couldn't find any result.
i bought an ebay fog light from edixworks.
I installed the fogs and fogs harness but am currently stuck on the switch harness.
here's a picture of the switch harness. http://i84.photobucket.com/albums/k2...-238388071.jpg
i got everything to fit, but the white plug that goes somewhere in the fuse box?
already plug in the relay, ground and switch plug.
http://i84.photobucket.com/albums/k2...209_161801.jpg
brown plug that goes into fuse box and brown plug that goes to hanging brown plug
http://i84.photobucket.com/albums/k2...209_161701.jpg
the fuse.
http://i84.photobucket.com/albums/k2...31209_1617.jpg
white plug that goes somewhere.
white plug suppose to go here but its not the right plug.http://i84.photobucket.com/albums/k2...-137209170.jpg
http://i84.photobucket.com/albums/k2...-137426031.jpg
any solution so i can make it work?
Old Dec 13, 2009 | 10:47 PM
livedc5's Avatar
Default Re: fog light problem rsx
I bought the same fog kit of ebay and ran into the same problem and i just ended up buying the oem wiring harness and switch cuz the the one that it comes with sucks ***!!
Old Dec 14, 2009 | 04:42 AM
kPRO dz's Avatar
it's not the greatest piece of wiring in the world.. you can either buy an oem harness, or you can hardwire it yourself!
Old Dec 14, 2009 | 05:56 AM
MUGEN_EM1's Avatar
it would be easier to wire the swith independently so you can have them on whenever you want instead of just with the low beams.
Old Dec 14, 2009 | 10:12 AM
TeeHee's Avatar
how would you wire the switch independently ?
Old Dec 14, 2009 | 06:26 PM
kobeballer96's Avatar
damn my ebay fogs for my ep3 was a cake. and the switch worked too for 45 dollars shipped! gl man that harndnesss looks wild.
red ignition power and yellow is continuous power, so use your brain
Old Dec 15, 2009 | 07:41 AM
kPRO dz's Avatar
PM me if you want a diagram of how you can install a switch.
I personally wired my fog lights to my corner lights
Old Dec 15, 2009 | 08:22 AM
this spring time we should cruise im only 15 mins from ellicot, city
Old Dec 15, 2009 | 04:34 PM
kPRO dz's Avatar
ill be in ellicott city in on thursday. did you attend any columbia car meets?
Old Dec 15, 2009 | 06:32 PM
noo for like honda - tech? i just go to hagerstown and chill there, there some cool ppl out there some nice cars same with Baltimore
Old Dec 16, 2009 | 01:49 PM
sinisterdc5's Avatar
i have the same i just wired them to my corner light the work fine
Old Dec 20, 2009 | 01:57 PM
2004ep3hatch's Avatar
Bad idea to do, you could fry your wires. The fogs take alot more current then those sidemarker light wiring are designed to handle.
This is what you should do, it's very easy. I used 12 gauge wire since i have HID's for fog lights.
Old Dec 20, 2009 | 03:27 PM
smart man ppl could use this it makes it easy for ppl that dont have the exp
Old Dec 22, 2009 | 07:18 PM
d16_2_k20's Avatar
Regarding the connection to the fusebox, what does it actually look like, or does it have that lable (IGN) on it? sorry for the nub question.
I would like the anytime switch since I have mine wired to running lights as well... thankz
edit: and which fusebox lol engine bay or under the dash
Old Dec 22, 2009 | 07:54 PM
under dash. the connector the goes in there is brown most of the time. research it
jdoherty2
Lighting
Dec 26, 2013 01:10 PM
tuby
Lighting
Nov 20, 2007 09:06 PM
tuby
Nov 20, 2007 06:12 PM
Schultzie
May 1, 2007 04:25 AM
