D16Z6 won't start! HELP!!
Old Dec 13, 2009 | 03:02 PM
turbodtaylor's Avatar
Default D16Z6 won't start! HELP!!
My D16Z6 won't start, drove all Thursday with no problems, had a CEL for a couple hours Wednesday but it cleared itself after a couple hours so I never got a chance to flash it and see what the code was. It was having no real problems running, except the occasional cut out at low R's. Then Friday morning it just wouldn't start, it cranks and cranks and cranks but no start. I checked for spark and fuel and had both then. Now it has no spark, but plenty of fuel and compression. I'm about to go downstairs and put a new rotor, ignitor and cap on it.
Old Dec 13, 2009 | 03:24 PM
Matt55's Avatar
Default Re: D16Z6 won't start! HELP!!
thanks for tellin us your daily plans
Old Dec 13, 2009 | 03:32 PM
DualCamGrahamn's Avatar
U know ur crank sensor is in ur dist. So after u change cap and rotor if that doesn't wrk and ur getting plenty fuel check the dist.
Old Dec 13, 2009 | 04:29 PM
delsolproblems's Avatar
Intermittent ignition problems are most often from a loose connection at either the grounds or the plug wires.
Old Dec 13, 2009 | 05:11 PM
fcm's Avatar
fcm
Old Fart
Before you go and spend time and money on something you may not need, check the obvious first, check and see if there ign. power getting to the distributor assembly, [probably a black/yellow lead], then move on the checking all the connections to the components inside the distributor, if all good then move on and check the components and replace if needed.
Diagnosing problems by replacing parts is an expensive way to go about it, and unless the parts are new you will not know, if car will still not start, if the part you replaced is also bad or is it something else. 94
Old Dec 14, 2009 | 12:16 AM
I was not telling my daily plans, I was asking for suggestions in case what I replace didn't work. I got new distributor parts from a friend who works at Honda, and the dizzy was the only thing left. I replaced the rotor, coil, and ignitor all for about $50 with new or nearly new Honda genuine parts, and she fired right up. Thanks for the input anyway guys.
JDW
Dec 10, 2010 09:39 PM
eric2407
Feb 21, 2007 07:21 AM
hmtcrxsir
11
Nov 28, 2006 02:47 PM
pabstj
Sep 6, 2005 07:24 PM
Sho Pow
Sep 27, 2004 08:20 PM
