retorque of ARP head nuts
Old Dec 12, 2009 | 01:22 PM
carnot's Avatar
Default retorque of ARP head nuts
I submitted a question to technical support on ARP's webpage concerning retorqueing the nuts on my H23 head. Their response is below but I have a follow up question.
"It is recommended that after an initial heat cycle you re-torque the head. To do so we recommend backing the nuts off one at a time and taking them back up to the recommended torque spec. Make sure to get the nut tightened to the correct torque before moving on and loosening the next nut."
For those of you that have done this, do you remove all of the torque from a single nut and then torque back to 80 ft.lbs or do you just loosen the nut, say one full turn, and then torque back to 80 ft.lbs. Thanks for any help.
Old Dec 12, 2009 | 02:36 PM
Doc13's Avatar
Default Re: retorque of ARP head nuts
What did you initially set the torque to? Was it more than 80ft/lbs? Basically you need to back it off to the point where when you you retorque it, it will be at 80ft/lbs.
Or maybe you should wait for their response..lol
Old Dec 12, 2009 | 02:42 PM
Matt55's Avatar
you are correct thats what backing off means
Old Dec 12, 2009 | 02:43 PM
Matt55's Avatar
oh im sorry, the second part was right just torque it then loosen it a little (one turn is fine aka backing off) then retorque
Old Dec 12, 2009 | 02:57 PM
carnot's Avatar
That is what I was thinking too. Seems like taking all the torque off the nut might cause bad stresses throughout the head. Nevertheless, I will post up what ARP says when they respond......they tend to make a few days for responses.
Old Dec 15, 2009 | 03:03 PM
carnot's Avatar
I got a response from ARP and wanted to post in case others have the same question in the future. Their response for how much to "back" the nuts off when re-torqueing the head.
"It is recommended to back off the nuts about 1/4 to 1/2 of a turn and
re-torque, they do not have to be backed off all the way."
Old Dec 15, 2009 | 07:14 PM
Doc13's Avatar
That is what I thought. It makes sense only to release tension not loosen.
G/L with your build.
avotegra
Dec 27, 2015 01:26 PM
Jdmb16sir2
Jun 10, 2007 05:50 PM
y2ks2k
Dec 1, 2005 06:52 PM
LudEcrous
May 4, 2004 01:47 PM
jdm_gsr
Dec 9, 2003 05:18 AM
