Idle problem
Old Dec 11, 2009 | 05:17 AM
00EckoSI's Avatar
Default Idle problem
I just installed a new exhaust from the header back with a test pipe and cat back...i reset my ecu because the check engine light came on when i moved the car with just the header on and when i drove it to my buddys shop (about40 miles) on an open header...now that i have everything on and reset the car at idle fluctuates from 1k to 2k and drops back to 1k and back up to 2k and keeps doing this...no CEL or any other issue..Any ideas
Old Dec 11, 2009 | 07:47 AM
delsolproblems's Avatar
Default Re: Idle problem
Does it do this only when the motor's hot or cold? Are there any times it doesn't do this? You sure the O2 is wired up properly? I don't suppose you checked the code?
Old Dec 11, 2009 | 09:04 AM
00EckoSI's Avatar
there isnt a code...it o2 was direct oe replacement i just pluged it in..it does it all the time
Old Dec 11, 2009 | 11:09 AM
This is the code I meant. Did you check it before resetting the ecu?
Old Dec 11, 2009 | 04:03 PM
00EckoSI's Avatar
yeh it said catalitic over threshold
Old Dec 11, 2009 | 09:33 PM
Check the grounds- thermostat ground, valve cover ground and battery negative strap. If they're ok, check the ignition, particularly the plug wires.
Old Dec 12, 2009 | 07:28 AM
00EckoSI's Avatar
ok i lied it only does it when the engine warms up
Old Dec 12, 2009 | 10:18 PM
It almost has to be an O2 problem. It's only happening when the computer is using the O2 sensors and that seems to be the only part you messed with that could cause this problem. I don't know if it's the sensor itself or just a loose wire but that's where you'll want to look.
Old Dec 12, 2009 | 10:38 PM
fastd16y7's Avatar
New User
iac?
house#21
Dec 22, 2009 08:29 AM
00EckoSI
Dec 11, 2009 09:15 AM
austin58x
11
Feb 22, 2007 06:50 AM
Akamaru
Mar 31, 2006 07:47 PM
4doorLX
11
Apr 5, 2002 05:52 AM
