What's Next after IHE mods? - NEW Here!
The camshafts are the next logical choice for upgrade. The reason is ease of installation and price as well as function. A good cam (or cam in the case of the D15-16) can increase your power more than any other single bolt-on and can complement your IHE upgrade hope this helps. Bisi has some really good cams for the D-Series engines.
You can't just get a cam and expect the rest of the valvetrain to last very long unless its a mild cam. Rebuilding the head and getting arp head studs and a new head gasket would be the next step. The head can come off without taking the motor out so thats a plus. You will also need slightly larger injectors and a tune if you want to get the most out of your setup. Its an on going never ending process, you will never be finished.
That's why I was asking about which motor. Because you might as well save up for a swap if you have a dseries for the best bang for your buck and at least you could still retain your exhaust and possibly your intake and sell the header to pay towards the swap.
new_climber
11
Jan 15, 2009 07:48 PM
blackeg
Dec 30, 2003 11:00 AM
Rob Dizzle
Dec 8, 2003 06:04 PM
