soon to order new motor, questions on which ecu to run...
Old Dec 10, 2009 | 04:31 PM
mikej94civex's Avatar
Default soon to order new motor, questions on which ecu to run...
ok, i recently had problems with my d16z6, (rev limit/no vtec). my buddy ran the cel scan
and the code it threw he said was for the cam positioning sensor, not sure of the code but he's
the mechanic not me. Anyways story short in 2 weeks i am ordering a d15b from hmotors
and was wondering could i use my p28 ecu or do i need the p06 from hmotors? I'm aware vtec is
5600 on the p06 and 4800 on mine, but would it be safe for the motor to run the z6 ecu?
Old Dec 10, 2009 | 06:06 PM
Default Re: soon to order new motor, questions on which ecu to run...
anyone....my buddy is running a p28 from a z6 on his mini-me (d15b nonvtec block z6 head)
and his car runs fine.
would my case be the same?
point is i don't want to buy an ecu if it's not needed.
-Thanks, Mike.
Old Dec 10, 2009 | 06:20 PM
Matt93eg's Avatar
5600 on the p06
Where do you get your ECU info? P06 is a Non-VTEC ECU in stock form. It runs the D15B7.
Old Dec 10, 2009 | 06:26 PM
my bad i meant p08 for the jdm d15b vtec...sry
Old Dec 10, 2009 | 06:37 PM
Matt93eg's Avatar
Its cool, from what I have seen most people that swap in a D15B VTEC seem to run the P28 ECU with the Z6 map without any problems.
Old Dec 10, 2009 | 07:05 PM
awesome! thanks man.
i was worried about vtec hitting soo much sooner and the timing and fuel curves, i just don't wanna buy a new motor and ruin cuz of somethin stupid on my part...thanks again!
Old Dec 10, 2009 | 09:20 PM
mrharmonic's Avatar
yea i agree run p28, but that is a little soon though
Old Dec 10, 2009 | 10:25 PM
civic_r87111's Avatar
If u use the P28 I'm 98% sure ur going to throw a CEL because the D15B doesn't use a VTP sensor and the P28 requires it, I read something about that on here but don't recall 100%.
Old Dec 10, 2009 | 10:29 PM
mrharmonic's Avatar
not if the p28 is chiped :D
Old Dec 10, 2009 | 11:18 PM
Originally Posted by mrharmonic
not if the p28 is chipped :D
True but it doesn't sound like that is the case here
Old Dec 11, 2009 | 12:56 AM
egsleepercivic's Avatar
can you swap it over from the z6?
Old Dec 11, 2009 | 09:45 AM
mrharmonic's Avatar
everything should work fine if you get a cel then you will know what it is and like i say not the best i dea but i like it chip the ecu
Old Dec 11, 2009 | 10:36 AM
I don't think there is a place for the sensor on the D15b head but maybe also if u chip the P28 ecu and tune it u can just turn that sensor off, either that or just use the P08.
Old Dec 17, 2009 | 12:55 PM
i hear the sensor is on the obd1's.....
JoeyEsco
Engine Management and Tuning
Aug 15, 2014 04:48 AM
ekphil
Sep 23, 2011 08:41 PM
Tong.Y
Nov 4, 2009 02:53 PM
wolf95
Oct 18, 2009 08:50 PM
Boosted Bondo Spot
Apr 30, 2005 12:47 PM
