oil pressure sensor on obd1?
Old Dec 10, 2009 | 05:46 AM
j.packsb's Avatar
Default oil pressure sensor on obd1?
i have a stock 2000 ex with a boosted d16y8. when i was tapping into the block at the oil pressure sensor, i broke it on accident, now after driving the car for 3 days, my oil light came on. i checked the oil and its fine. could the chipped obd1 ecu be throwing the oil light on because the sensor i broke or is it something else? i didnt think the obd1 ecu even had an oil pressure sensor..? any ideas? thanks in advance
Old Dec 10, 2009 | 05:54 AM
dpetro1's Avatar
Default Re: oil pressure sensor on obd1?
the oil pressure sensor is just a dummy light that turns on at <5psi and is not controlled by the ecu in any way.
is oil lekaing from oil sensor? what exactly did you break?
the only way the light would come on is if the sensor is plugged in and not getting pressure. i would figure that out asap because if you really have no oil pressure then your motor is gonna be destroyed quickly
Old Dec 10, 2009 | 06:37 AM
j.packsb's Avatar
i broke the wirring off the actual plug. im leaking oil somewhere but i cant find it. but after i filled the oil up completely to the 2nd dot on the dipstick, the oil light still stayed on..?
07CRV
Honda CR-V & Element
Sep 30, 2016 04:07 AM
j.packsb
Dec 10, 2009 10:23 AM
eag36
Apr 6, 2005 07:55 AM
crxY-49
May 12, 2003 03:01 PM
