oil pressure sensor
Old May 12, 2003 | 10:31 AM
crxY-49's Avatar
Default oil pressure sensor
i did a search and found nothing...
If I remove the oil pressure sensor for my oil feed line will the "check oil" light come on? Thanks.
Old May 12, 2003 | 10:36 AM
Spudddy's Avatar
mine was disconnected for 2 months and the light never came on
Old May 12, 2003 | 10:37 AM
crxY-49's Avatar
Default Re: (Spudddy)
sweet...thanks man
Old May 12, 2003 | 10:39 AM
PM-Performance's Avatar
Default Re: (crxY-49)
no it wont.
Old May 12, 2003 | 01:16 PM
GOLDBERG's Avatar
Default Re: (itr206)
honda sensor is a peice of ****...if u ever see the light your already in deep **** a few weeks back but no..it wont
Old May 12, 2003 | 01:34 PM
Kimbo's Avatar
Default Re: oil pressure sensor (crxY-49)
Id use a t for it anyhow because wont the ECU go limp if it reads no oil pressure?
Old May 12, 2003 | 02:51 PM
93LSivic's Avatar
Default Re: oil pressure sensor (Kimbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kimbo &raquo;</TD></TR><TR><TD CLASS="quote">Id use a t for it anyhow because wont the ECU go limp if it reads no oil pressure?</TD></TR></TABLE>
No, you are completely wrong. The sensor is only a pressure switch that will ONLY send a ground signal to the idiot light on your gauge cluster......pretty much your fucked if it ever comes on cause there will pretty much not be any oil in the pan.
Old May 12, 2003 | 03:01 PM
psileepR's Avatar
New User
Default Re: oil pressure sensor (93LSivic)
Removed it months ago to put in my oil pressure gauge... no ECL.
never knew that 93LSivic ... learned something new
07CRV
Honda CR-V & Element
Sep 30, 2016 04:07 AM
j.packsb
Dec 10, 2009 06:37 AM
Rukusmasta2
May 5, 2008 03:30 PM
eag36
Apr 6, 2005 07:55 AM
