p29 rods
Old Dec 9, 2009 | 08:33 PM
prelude182's Avatar
Default p29 rods
will p29 rods fit onto a d16 crackshaft? i know they dont fit on d15 crackshafts because the p29 rods are bigger.
Old Dec 9, 2009 | 09:13 PM
C_R_X_V_T_E_C's Avatar
Default Re: p29 rods
why p29 rods why not just use ls rods?
Old Dec 9, 2009 | 11:00 PM
prelude182's Avatar
because im too lazy to take the pistons apart, and i do not have the funds for ls rods and i already have the necessary parts to do a mini me swap, so i was just wondering because ive been questioning myself about it for awhile.
Old Dec 9, 2009 | 11:13 PM
DCRB's Avatar
yes p29 rods fit on d16's. the motor they came out of are d16's. same rod, different piston.
Old Dec 9, 2009 | 11:15 PM
zackly.
i was just curious as to why you would want to use them, you have the 29 pistons as well? those would make some killer compression in that mini me.
Old Dec 9, 2009 | 11:20 PM
DCRB's Avatar
Originally Posted by C_R_X_V_T_E_C
zackly.
that's what i'm going to do... although i'm going with aftermarket rods.
Old Dec 9, 2009 | 11:41 PM
garageEF's Avatar
Why would you ever use LS rods?
They DO require modification to fit and are only slightly stronger than the stock pencil-sized rods, which should hold up fine to the power an NA D16 will make.
OP, if you're too lazy to change the rods out how are you building a motor?
Old Dec 11, 2009 | 08:07 AM
well i generally have a plethera of honda parts and we did the channeling and the machine work to some ls rods i had, they worked out great, im was unaware if the OP was mechanically inclined or not/ and had access to a machine shop
team_lunatics
Oct 13, 2011 08:15 PM
CanadianEF9
Nov 8, 2010 04:16 PM
swepper
11
Apr 22, 2009 01:56 PM
RACEPAK
Jul 14, 2007 06:49 PM
Civic138
12
Feb 9, 2007 03:03 PM
