moates burn2 problems ! CROME 1.5.3
Old Dec 9, 2009 | 05:23 PM
teamjdm239's Avatar
Default moates burn2 problems ! CROME 1.5.3
i go to settings, have it on com port 4 , baud rate 920000, and i test connection. "successfully connected to ecu"
but when i go to burn the bin. it says no connection detected. :/
then, i close crome, i re-open it, and reopen my bin file.
i hit write , and it says "the operation failed after 3 attempt(s) with 250 milliseconds between each attempt.
Old Dec 10, 2009 | 08:28 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: moates burn2 problems ! CROME 1.5.3
mine did this. restart your laptop then try it. if it still does it try dif coms
Old Dec 10, 2009 | 10:11 AM
teamjdm239's Avatar
i tried man. i tried switching com ports, and baud rates, but it just doesnt seem to wanna work.
Old Dec 10, 2009 | 10:16 AM
I'm not Rick!
are all the wires in the ribbon dealy in good shape?
sometimes putn the cover on the ecu can cut that ribbon.
did you try another laptop? it could be the driver
i had lots of problems with the driver not working. and i had to upload new ones via internet..
im getting hondata s300 soon. i know its more $ of course
with crome i cant get a redline to work.
vtec isnt consistent.
iacv activity flucuates and isnt consistent
and several laptops have to fight to connect to the ecu
lots of people like crome but i think it still has so many problems its not worth even downloading for free.
Old Dec 10, 2009 | 10:31 AM
teamjdm239's Avatar
emulation works fine, just the burn2 isnt burning the chip its a compatible chip . i just dont wanna keep driving with the ostrich 2 in my car. :/
and yes, this is the 3rd laptop ive tried. still nothing.
Old Dec 10, 2009 | 10:37 AM
HRTuning's Avatar
It's 921600, not 920000. You'll have to manually enter it, since the option apparently isn't available in the baud rate list. There's your first step to try.
Old Dec 10, 2009 | 10:40 AM
teamjdm239's Avatar
ill try it now, get back to you in a sec.
Old Dec 10, 2009 | 10:45 AM
teamjdm239's Avatar
still the same thing. i hit detect connection, manually entered 921600, hit apply, then closed crome, opened it back up, and still the same message.
Old Dec 10, 2009 | 02:42 PM
bigD's Avatar
are you checking the the baud rate and com in device manager also?
Old Dec 10, 2009 | 02:57 PM
HRTuning's Avatar
The software sets the baud rate. It ignores the value that's shown in device manager.
The COM port and latency settings should be checked in device manager, though.
Old Dec 10, 2009 | 04:38 PM
teamjdm239's Avatar
so while its running i should check the device manager?
Old Dec 10, 2009 | 05:35 PM
HRTuning's Avatar
After you plug in the USB device... It shows up in Device Manager.
Old Dec 10, 2009 | 07:22 PM
MONSTERek4's Avatar
email me ur bin and ill burn it on a chip for you free of charge just pay shipping
Old Dec 10, 2009 | 07:46 PM
teamjdm239's Avatar
well no matter what, i need to get this thing working, dont mean to be rude.
Old Dec 10, 2009 | 08:06 PM
bigD's Avatar
try this http://www.xenocron.com/install/HowT...echArticle.htm
Old Dec 12, 2009 | 10:13 AM
teamjdm239's Avatar
found out what it was. it was the 27fs512 compatibility option. i clicked on that, and now it burns freely. thanks for all the help fella's
Old Jul 30, 2018 | 10:14 AM
PUTANI's Avatar
where is this option could you help me unable to find this in crome.......
I am having same issues burning the chip
Veggie Man
Engine Management and Tuning
11
Jun 14, 2015 04:20 PM
a1320honda
Sep 17, 2014 05:42 AM
allmotor-B
12
Aug 29, 2011 04:21 PM
apexrift
Oct 22, 2009 07:29 AM
k20em2
Oct 4, 2004 12:18 PM
