helpppppppppp!!!!!
i have a d16z6. i recently changed the alternator. after that i have had a problem with my rev limiter and vtec.
vtec won't engage and my limiter hits at 5,500 vs. 7,200. my ecu is a virgin, i reset it also and
replaced my fuses. I also replaced all my grounds and checked all my electrical connections....
please somebody what could be the problem?
well that is going to make this process almost impossible. that light will lead you directly to the problem and will save all the guessing and time. can you get that fixed and re-diagose?
Did you even read the forum sticky on topic creation?
https://honda-tech.com/forums/showthread.php?t=2407755
MAKE YOUR TOPIC TITLES SUBJECT SPECIFIC! NOT JUST "HELP" ETC.
Originally Posted by B18C5-EH2
Topic title is self explanatory.
Do everyone a favor, including yourself, and please post subject specific topic titles.
Example?
Let's say you're having trouble with a B18B OBD1 engine swap into a 1995 Civic and you're throwing some check engine codes, and the engine won't start.
A good topic title would be:
"Help with B18B swap won't start in my 95 Civic
A bad title, and a common title we've been seeing more and more of lately:
"Need help"
or
"Emergency!"
or
"Got a Question!"
You get the idea. Not only will this get quicker specific help from other people who have experiences the same problem or helped with it, but it also gives other H-Ters key words to search when they encounter similar problems.
It's a waste of resources for an excellent tech topic that answers some very specific questions/problems cannot be searched and found under our search engine because it's title was a vague "Got a Question" etc. etc.
From now on please keep this in mind, thanks.
Example?
"A bad title, and a common title we've been seeing more and more of lately:
"Need help"
or
"Emergency!"
or
"Got a Question!"
go replace the burnt light bulb for like 5 dollers.. and check on code, then come up on this forum and look at the cel thread for the code.... then post up here and we will help you when we have found your malfunction,
but right now im just thinking something with the intake.... safe mode
k kidcorner, i did that cuz i posted earlier with expanation and nobody barely replied....anyways thanks guys i willreplace that bulb friday and get back to u on what code it is.
but would changing my alternator trigger anything that would cause that probelm j/w?
no alternator wouldnt fix the problem.... alternator is just to charge up the battery really....
i think its one of your sensors thats causing it cause my buddys 04 civic ex had the same problem except at 4k rpm limit, no vtec and he bring it in...
timing belt was screwed, one of the sensors on the intake manifold was bad, and that set off his safe mode
oh-k
Sep 20, 2004 02:09 PM
