blocked off iacv and fitv, any downfalls?
Old Dec 9, 2009 | 12:19 PM
blasterman87's Avatar
Default blocked off iacv and fitv, any downfalls?
i blocked them both off using thin aluminum(beer can) and some high temp silicone. i just put it between the valves and bolted them on like normal, i then adjusted the idle as follows.
cold start, nothing on 700 rpm
warm nothing on 1000 rpm
warm heater/headlights high beam on 600 rpm
does anyone see any problems with this? i like how it runs so far, and all my coolant lines going to the intake are blocked off including the ones to the iacv and fitv
Old Dec 9, 2009 | 02:48 PM
4drEF's Avatar
Keyboard Humorist
Default Re: blocked off iacv and fitv, any downfalls?
so... why did you do this?
Old Dec 9, 2009 | 02:51 PM
ed4doorcivic's Avatar
ya what is this for?
could u not find any?
Old Dec 9, 2009 | 02:54 PM
no they were both on there, they didnt have any hoses going to them and i had a idle problem so i decided to get rid of them. if it has no faults like this i will make block off plates from aluminum instead of cans for a cleaner look(to get rid of them completely)
Old Dec 9, 2009 | 02:56 PM
hmmm...
Old Dec 9, 2009 | 02:57 PM
4drEF's Avatar
Keyboard Humorist
Have you done the standard fixes for these?
They commonly fail and are easy to fix.
Idle bounces up and down if they are bad... not sure what idle issue you had.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-fix-your-idleing-woes-fitv-iacv-2153910/
Old Dec 9, 2009 | 02:59 PM
yes, i cleaned them but i figured if there not needed then why have them? makes for a cleaner bay and simplifys things
Old Dec 10, 2009 | 10:58 AM
DPSJosh's Avatar
It's all good now, but once you change elevations, weather conditions, etc, it will probably idle like crap. You've taken away the computers ability to control idle for different conditions. You can block everything off but you lose that ability for the computer to adjust idle for certain conditions such as air density, temperature, elevation, engine or accessorie drag, etc. I would definetly try to fix the original problem instead of block everything off.
Old Dec 10, 2009 | 02:30 PM
89s1's Avatar
I would maybe do it to a track only car, but certainly not a daily driver.
LONO100
Feb 22, 2012 02:10 PM
JDM-KIDD
Aug 4, 2009 05:22 AM
dohc_profile
Feb 17, 2009 09:19 AM
efyou
Apr 18, 2007 06:00 PM
