Suspension & Brakes Theory, alignment, spring rates....
tie rod stuck, can't get it off, advice??
Old Dec 9, 2009 | 10:05 AM
Milab21's Avatar
Default tie rod stuck, can't get it off, advice??
I just did a 5 lug swap on my 99 civic si. The driver side tie rod i had to cut the nut from the ball joint off because the nut was spinning with the bolt. Anyway I got a new tie rod from honda, and I just can't get the locking nut loose on the tie rod. I tried heating it up a little bit, wd40, it just wont come off. Any ideas would help greatly, please so I can drive my car again!
Old Dec 9, 2009 | 10:14 AM
kyden's Avatar
Default Re: tie rod stuck, can't get it off, advice??
the locknut that secures the inner tie rod to the outer tie rod? if you truly can't get it off, its time for a new inner tie rod. i can't see why it wouldn't though if you got the outer tie rod off (i'm assuming)
Old Dec 9, 2009 | 10:17 AM
Milab21's Avatar
yes that one, i"m gonna try again today, I'm just looking for tips, i don't feel like buying a new inner tie rod but if it comes down to it, i will.
Old Dec 9, 2009 | 12:05 PM
kyden's Avatar
all i can really say is get a 14mm wrench to hold the rod in place while you loosen the nut.
Old Dec 10, 2009 | 11:22 AM
Milab21's Avatar
i heated it up for like 6 minutes with the tourch and used a pipe wrench! i got it, its back on the roads!
RootMode
Feb 16, 2019 04:52 PM
BIGef
20
May 5, 2013 03:38 PM
skipbudlong
31
May 6, 2010 10:21 AM
Groove_D
Nov 13, 2005 11:36 AM
SlammedBlueEM2
Aug 4, 2004 04:45 PM
