wich paint job??
i just bought a 98 hatch and want to get it painted, i dont really know much about this subject so i'm requesting your help. Whats the difference between a 2 stage and 3 stage paint job?? i just want to get a basic oem red paint job, what kind of paint job do you guys sugget i get
there is nothing wrong with single stage.. all the newbs believe singlestage = shitty paintjob... but single stage can be just as durable and nice as anything else...
2 stage just means theres a layer of paint then clearcoat
three stage is usual paint then pearl then clear....
for the most part these paint jobs all vary in price... so choose your destiny
thanks 4 the help, i've never had to paint a car before and when i bought this one i knew i was gonna have to do it cause it has some front end damage and i dont like the color the car currently has, i'm gonna do the '00 front end conversion and paint the whole car. SINGLE STAGE PAINT!
single stage is a base/clear mixture sprayed all at once, you can get this pretty much in any factory color
2 stage paint is basecoat/clear coat sprayed seperately so that your clear coat is just clear, and entirely free of any base, this makes the compound and polish process easier and generally gives a much better finish
3 stage paint is specialty paint, usually associated with expensive *** pearl paints from house of kolor or other very expensive paints
no flamenco black pearl can be had in both a single stage and 2 stage paint, the pearl coat is mixed with the basecoat and then clear is sprayed on top typically with the 2 stage, in single stage they are all mixed together, but the issue with the single stage is you really shouldnt compound and polish this because you run the risk of flipping the metallic.
also, flamenco black pearl is black basecoat with silver pearl mixed in, nighthawk black pearl is black basecoat with blue pearl mixed in
civiceg500
Oct 18, 2004 06:03 PM
single stage paint job FTW
