vtec problem
ok i have a b16bottom block with a gsr head and its all stock with a gsr trans and its running on a chipped p61 ecu(b17 92-93 gsr)....and my problem is that for soem odd reason when i hit it in first its fine then second its fine then once i hit third gear and v tec kicks its like making a sound of it like jus not normal and v tec doesnt work with check engine light poping on and after that itll do that for all gears but once u turn off the car it goes away untill u hit it again so can some one help me on this situation......im sorry i cant explain it really good but when i get my camera back ill try to record my problem im trying to find out
pull the code first and then we have a place to start
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
