None of my windows work!
Old Dec 7, 2009 | 07:09 PM
JforJonathan's Avatar
Default None of my windows work!
I have no clue....none of my power windows will roll down on my 97 civic lx sedan. I checked each door and none of them will roll down. What could it be? I'm lost. I've checked the fuse but its not burned out.
Old Dec 7, 2009 | 07:27 PM
itsnotfast's Avatar
Default Re: None of my windows work!
Driver door pwere window switch, fuses, broken wires in the door jamb, it could be many things.
Old Dec 7, 2009 | 07:30 PM
Blue_eg95's Avatar
Dunno the wiring diagram for that car. But if the power for each window goes through the main switch, the power wire going to the switch may have an open or the switch may be broken.
when you push teh down button does it sound like they are trying to go down? If you push up does the motor make any sound? If you listen closely, the motor should make a small sound even if the window doesn't move.
Old Dec 7, 2009 | 07:31 PM
thumper64's Avatar
Probably a dumb question, but did you turn the car on?
Old Dec 7, 2009 | 07:43 PM
Former User's Avatar
There are multiple fuses to check:
-40A hood fuse 46
-7.5A dash fuse 24
-20A dash fuses 7, 8, 10, 11
Old Dec 7, 2009 | 07:44 PM
itsnotfast's Avatar
I swear ^ this guy has the answer for everything lol.
Old Dec 10, 2009 | 07:09 PM
When I push the switch, I don't hear the motor making any noise at all. None of the motors make any sounds, I checked each door's switch.
Yeah, the car is running.
Old Dec 10, 2009 | 07:13 PM
-40A hood fuse 46
-7.5A dash fuse 24
I replaced the 40A hood fuse, still nothing.
How do I check the dash fuses? Just pull them out and look for a broken connection?
Also, Is there supposed to be any light at all on my drivers door window switch? Is the AUTO supposed to be lit up? I have no lights at all on my switch.
Do I have to pull the whole door panel to replace that whole drivers door switch pod? I can't get my door panel off at all.
Thanks for everyone's help thus far....I am determined to get my windows working!
Old Dec 15, 2009 | 03:42 PM
Well, I've checked all fuses referenced above. They are all good. I've also changed the relay to a new one. I also changed the master switch on the door and the windows still don't work! What am I to do next?
Old Dec 18, 2009 | 03:50 PM
Problem solved. There was a wire in the door jam that was cut/broken. I just soldered it back together and now my windows work!
Old Jan 14, 2010 | 10:24 AM
Wish2345's Avatar
i have the same problem in my SI, i will have to check for broken wires or the drivers switch b/c all my fuses appear to be good
Old Jan 15, 2010 | 03:45 PM
yeah try checking the wires in the doorjam first. All you gotta do is pull that black conduit off the wires. luckily, right when i pulled the conduit back, i saw a broken wire right there.
USA
Oct 2, 2021 03:13 PM
Jakester9500
Mar 28, 2016 07:57 AM
crex-ef
Jan 4, 2010 07:07 PM
James
Nov 20, 2002 12:26 PM
