TD05 14b for my LS???
Old Dec 7, 2009 | 06:53 AM
boosted_LS95's Avatar
Default TD05 14b for my LS???
So im planning on putting a 14b in my LS. My question is do you think I can make over 200whp and if so with how much boost?
Old Dec 7, 2009 | 08:10 AM
Hemix's Avatar
Default Re: TD05 14b for my LS???
Where do you live? If you live near sea level, I bet you could get 200whp on the stock WG (8psi). I am putting down around 190whp up here in Colorado (5800ft) on a stock LS with a 14b running the stock WG, so I would estimate that you'd be over 200whp at sea level given that overall you'd be running ~2 more psi than me.
Old Dec 7, 2009 | 08:31 AM
GsrIntegra789's Avatar
My experiences with the 14b is it will make really close to 200whp on a stock motor. This isnt always a guarantee since it depends on a couple of things, such as your manifold of choice, size of charge pipes, exhaust size etc. and of course, your tuner.
Old Dec 7, 2009 | 08:57 AM
Thanks guys! I live in the twin cities (about 800ft.). I understand that there is alot of variables but i just wanted a ballpark idea of what to expect from this turbo setup. I got a 14b, ssautochrome manifold ( w/ added support brackets by me), 450cc DSM injectors, 1g BOV, chipped ECU, crome basemap, ebay intercooler w/ homemade piping, 2.5" turbo back exhaust w/ cat delete, stealthmode oil lines, ect... your basic poor man Honda/DSM turbo setup lol. I appreciate all the feedback and im happy to hear that i will beable to achieve my goal of around 200whp running my stock WG. Hows did you guys like the 14b on the ls motor? Does it start to pull at a good RPM? Does it pull nice? or does it give out too early like i hear so many people say? My friend is running a T3/T4 on his d16 and it doesnt start to pull until around 5k. Kind of pointless IMO.
Old Dec 7, 2009 | 11:44 AM
inspector01's Avatar
Im assuming you mean the twin cities, MN?? If so, hit up Ron at RS motors to tune, he uses a mustang dyno which will read a bit lower than most, but he is a great tuner with awesome customer service. The 14b should spool pretty damn fast, but with an LS you hopefully won't run out of steam up top. Its smaller than I would put on an LS, but should be some fun low end torque for city driving.
Old Dec 7, 2009 | 12:00 PM
94LS_allmota's Avatar
i had a td4h greddy turbo kit on my b16 and it reached 7psi befor 3.5k rpm and pulled nice the whole way.....only problem i had i drove it hard and lasted 2 months before i blew a headgasket.....u might wanna get sum ARP headbolts.
Old Dec 7, 2009 | 05:51 PM
Hemix's Avatar
I get full boost (8psi) at 3k and it doesn't taper off at all up to the limiter at 7.2k.
Old Dec 7, 2009 | 06:54 PM
Thanks guys for all the input! It sounds like this turbo setup is exactly what im looking for. I cant wait to get it running! I plan on keeping the A/C and pwr steering. Do you guys think this is possible without relocating anything? And does anyone know the hp potential of the 14b? Again thanks alot, I really appreciate the help!
Old Dec 7, 2009 | 08:05 PM
Scotty Dosent Know's Avatar
Boost may not taper off up top but what about power? Have you ever had it on a dyno? thats the only real way to tell.
Old Dec 7, 2009 | 10:27 PM
TheShodan's Avatar
Moderator
You had Greddy 15G. VERY different from a Td04-14b. They are completely different w/ similar housing. you don't need ARP bolts for something this underpowered.
This is a 14b
This is a 15G - Not quite a Greddy 15G, but close
Old Jan 1, 2010 | 04:35 PM
cadeMFjohnson's Avatar
"You had Greddy 15G. VERY different from a Td04-14b"
td04 is a 13g
14b is a td05, 13-automatic 1st gen, 14-standard trans
little bigger. you probably knew, prolly just a typo, anyways i know im a bit late to the thread but i run a b16, slightly thicker cometic 3 layer steel head gasket and arp head studs. my w/g opens at ten psi stock though? anyways i am usin an ebay manifold and intercooler/piping set and i managed 256 whp in oklahoma, about sea level.
im stepping up to the 14b. its already in the mail. along with a gm 3 bar map and a wastegate dumped o2 housing. hoping to hit 280-300whp with a couple more psi and a better tune
Old Jan 2, 2010 | 06:29 AM
TheShodan's Avatar
Moderator
td04 is a 13g
TD04 is a standard housing size, not just a wheel size, we've put 15g 3000GT upgrades in TD04s. TD05 can take anything from a 14b-20G.
to get 300whp on a 14b, you got to push MAJOR pressure through to it. If you want to try it while pushing in a lot of hot air.. Go for it.. I'd like to see your results.
Old Jan 2, 2010 | 10:08 AM
really? even though i'm a step down turbo wise right now with less boost and hitting 256whp? hm. well i guess the efficiency range for the 14b isn't THAT much higher than the 13g
if i don't hit my mark, i'll just drive it for a year then build the engine and swap to a t3/t4. ball bearings ftw lol
Old Jan 2, 2010 | 09:10 PM
TheShodan's Avatar
Moderator
Here is a 13g
The 13G is 360cfm while the 14b is 378cfm. not much of a difference. this is at over 14psi for these measurements.
Old Jan 2, 2010 | 09:12 PM
carbon fiber coupe's Avatar
i made 220whp on my ls vtec with a td04h on 7 psi
Old Jan 3, 2010 | 11:32 AM
thanks for the map shodan
ZackwiththeEG
Jul 7, 2016 11:12 PM
LS94tegra
Aug 20, 2009 03:59 PM
killablaze
Nov 16, 2005 07:25 AM
slow hatch
Sep 22, 2005 02:28 AM
Nickyj1211
Nov 9, 2004 07:25 PM
