Help! Poor Mans R Question
Old Dec 6, 2009 | 11:07 AM
>-Mika-<'s Avatar
Default Help! Poor Mans R Question
So I got a Poor Mans R (B18C1 bottom end and a JDM B16A head). The GSR block has GSR timing belt parts (16T crank cog and 22T water pump with GSR tensioner). The B16A head has AEM Tru-Time 3 bolt cam gears, not sure if that makes a difference at all but regardless.
Anyways my question is, what timing belt works?
I tried a GSR belt and it has way too much slack, approx 90 degrees of deflecting in the belt and a SiR belt won't even fit unless I toss the tensioner, and that's not even ****ing possible.
Any help is appreciated here! :D
Old Dec 6, 2009 | 11:12 AM
trrbl1bmx's Avatar
Default Re: Help! Poor Mans R Question
It has too much slack after the tensioner is maxed out?
Old Dec 6, 2009 | 11:13 AM
trrbl1bmx's Avatar
Just curious how your measuring belt deflection in degress?! Jus sayn
Old Dec 6, 2009 | 11:27 AM
>-Mika-<'s Avatar
Yeah tensioner is MAXED right out.
I don't mean exactly 90 degrees, but I mean I can turn the timing belt to basically look right AT the ribbed portion that rides the cam gears etc.
Old Dec 6, 2009 | 11:41 AM
commguy's Avatar
I would think that the B18C Type R belt would be the ticket as the cam gears on the GSR may sit higher. That is, however, just speculation.
Old Dec 7, 2009 | 09:01 AM
>-Mika-<'s Avatar
Bumpity!!
GSR/Type R are 1 tooth in difference and an LS is 2 teeth off.
Also, B17 GSR and Civic SiR are the same tooth count!!
I need help bad or this won't run at all.
Old Dec 7, 2009 | 09:19 AM
bar'dh22's Avatar
your setup is not a true Poor Mans R you would need type r pistons also
Old Dec 7, 2009 | 12:06 PM
>-Mika-<'s Avatar
What does the Type R pistons have to do with my question at hand?
I have B16A pistons in the block on GSR rods/crank, which yields a 11.1:1 compression ratio.
Old Dec 7, 2009 | 06:45 PM
redline7070's Avatar
b18c5 belt
david420
Apr 8, 2012 10:32 AM
preludedriva
Jul 29, 2007 12:10 AM
ToFu-DeLiVeRy
Sep 21, 2004 05:47 PM
RCautoworks
25
Aug 15, 2004 09:17 PM
