89 crx speedo help!
Old Dec 5, 2009 | 04:44 PM
corey89crx's Avatar
Default 89 crx speedo help!
i have a dc16z6 out of a 92 si hatchback an the original 89 crx cable tranny and the new computer is throwing a check engine for the speedometer not working. How do i wire or rig up to get the check engine off?
Old Dec 5, 2009 | 08:01 PM
424racer's Avatar
Default Re: 89 crx speedo help!
just put the vss cable back into the vss.
you dont have to do any wiring,
Old Dec 6, 2009 | 07:40 AM
McGruber's Avatar
Is your speedo working or not?
Old Dec 6, 2009 | 08:18 AM
corey89crx's Avatar
noo the speedo is not working...
Old Dec 6, 2009 | 09:41 AM
McGruber's Avatar
Ok, then do what 424racer said. There is a retaining clip that holds the cable into the vss sensor and sometimes if that comes off or is loose the cable can come out.
Old Dec 6, 2009 | 11:23 AM
turbohatch322's Avatar
Where exactly does it go? my speedo is out too. i found the cable but cant find where it plugs in to. Thanks!
Old Dec 6, 2009 | 11:26 AM
crxcess's Avatar
deleted
Old Dec 6, 2009 | 11:28 AM
matt17249's Avatar
It goes in a hole of the VSS on the back of the tranny. It faces upward and is located above the shift linkage on the back
Old Dec 6, 2009 | 12:41 PM
hatchet_honda's Avatar
x2 just insert the cable end into that hole in the top of the trans. make sure you put the lil clip in there too. and thats weird its throwing a code for the vss..what ecu? i have a p28 in my d15b and dont have any cel issues for the vss. using the cable..no problems
Old Dec 6, 2009 | 06:16 PM
Ok i plugged it in an its still not working. any thoughts? thanks!
Old Dec 6, 2009 | 08:08 PM
McGruber's Avatar
Did you use the retaining clip? Make sure it's in all the way, both the cable and vss. Also reset your ecu, you can do that by disconnecting your negative battery cable or removing your ecu fuse. Hopefully that will fix your problem.
Old Dec 6, 2009 | 08:37 PM
frank_el_tanke's Avatar
what's not working the spedometer or the check engine light not turning off?
if it's the check engine light that you're referring to then do as suggested above.
if your speedometer is the one that isn't working then it could be your speedometer is malfunctioning, your cable is broken, or your vss is malfuntioning.
Old Dec 6, 2009 | 09:28 PM
What is the vss? its my speedo an i think then retaning clip is gone??
Old Dec 6, 2009 | 10:46 PM
424racer's Avatar
vss= vehicle speed sensor...
the cable slides into a little slot in the speed sensor on the tranny. it will still work woth out the locking clip.
where are you located?
Old Dec 7, 2009 | 12:07 AM
colorado. why? thanks
Old Dec 7, 2009 | 05:41 AM
the vss is the thing stickin up from the top of the trans...the end of the speedo cable fits inside
Old Dec 7, 2009 | 07:38 AM
McGruber's Avatar
Yo turbohatch322, where in Co are you located? I'm in Greeley and Boulder.
Old Dec 7, 2009 | 07:51 AM
montrose.
Old Dec 7, 2009 | 08:34 AM
McGruber's Avatar
Dam, in the boonies that's like 7 hours away lol.
Old Dec 7, 2009 | 10:35 AM
ya lol it is.
Old Dec 7, 2009 | 03:31 PM
matt17249's Avatar
The vss is the thing that the cable goes into. If your speedo still doesnt work then remove the VSS from the tranny and visually inspect if for damage. Then spin the gear and look down the hole where the cable goes into it. Do you see any thing moving? if you do then it most likely works. If the vss is working fine, then pull out your gauge cluster and remove the speedo cable from it. Have someone spin the cable at one end and see if it moves at the other end. If it does you most likely have a problem with the gauge inside the cluster.
digitalernest
Feb 15, 2011 07:54 PM
silentdarkness1317
Classic Hondas
Sep 1, 2010 03:30 PM
Nick998
Mar 2, 2010 07:25 PM
1SIKCRX
Jul 14, 2004 10:52 PM
Monty
Oct 5, 2002 09:46 AM
