purpose of 150 mph spedo??
Old Dec 5, 2009 | 10:56 AM
blasterman87's Avatar
Default purpose of 150 mph spedo??
why did honda give the jdm sir spedo a 150 mph limit? what is the purpose of a high limit like that? the tranny isnt even capable of those speeds.. just something i thaught was weird
Old Dec 5, 2009 | 11:11 AM
.Manny.'s Avatar
Touching My Member
Default Re: purpose of 150 mph spedo??
I'm pretty sure you can get up there. And I think the cluster you're referring to is the UK cluster. Would I do it, yeah, but not on the street.
Old Dec 5, 2009 | 12:24 PM
gibsanez's Avatar
The stock engine and transmission isn't capable, no. But that doesn't mean a K series or H/F series isn't.
NO TECH!
Old Dec 5, 2009 | 12:38 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
B.S. they are not capable. You just have to be able to REV it higher...
Old Dec 5, 2009 | 12:46 PM
1kleenef's Avatar
You ever come to think that maybe they wanted to just raise the tach number and instead of using a d series redline - 6800 they would increase both tach and mph for the b series engines in those cars?
Old Dec 5, 2009 | 01:11 PM
crx_si-r's Avatar
i love mine....
and as stated you are referring to the UKDM cluster. JDM clusters are in Kilometers per hour (KPH)
i have one of those too....
Old Dec 5, 2009 | 02:06 PM
Blaze45's Avatar
Brrraaaap!
I am assuming that you had to get the speed sensor that went with the cluster for it work properly, no? I like it. Did you have to purchase anything else to make it work properly?
Old Dec 5, 2009 | 02:16 PM
0ne-Cam's Avatar
wtf is this thread about, theres no tech just show off clusters? go hit 150 on a country road where theres no living thing around
Old Dec 5, 2009 | 02:20 PM
crx_si-r's Avatar
i mainly got the cluster because my old speedometer was slightly off, about 5 miles, and i went with this as a replacement. and now im right on the dot. when using the UKDM cluster no additional parts were needed. When doing this you only need to remove the gauges from UKDM cluster and swap them onto your old cluster (as long as you already have a tach on your cluster) and your done. you do not need to change your VSS.
you only need to change the speed sensor on the JDM cluster
t0ekn3e
14
May 5, 2010 05:43 AM
jeffy
Feb 19, 2007 03:43 PM
black91gs
May 28, 2005 08:23 PM
Luchini
Nov 9, 2004 04:20 PM
