clutch problem
OK so i have a 94 h22 accord and my clutch felt a little spongy as if my slave or master cylinder was going out.So i changed both of them. Well i had pressure but i wanted to bleed it a couple more times then the next two times i lost pressure completely. I changed the slave an master cylinder again an now i have no pressure at all after Ive been bleeding for 2 hours. An as were bleeding now the fluid in the master cylinder doesn't even go down it stays at the same level. An I cant get any pressure at all an i dont know what it is can somebody please help me
When was your swap? did you hit the clutch dampener when putting in the transmission? When I was swapping transmissions I accidentally hung the transmission on my clutch line and the dampener sprung a leak, one that doesn't leak fluid, but introduces air into the system.
T"u"Rtle
Apr 21, 2006 10:17 AM
