Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
08 Civic Si Sedan Steering Problem
Old Dec 4, 2009 | 11:19 PM
08Si-R's Avatar
Default 08 Civic Si Sedan Steering Problem
Ive searched and cant seem to find anything on this. When I hit the brakes the car will suddenly jerk to the left. But whats confusing is that the steering wheel will jerk to the right. I am completely lost on this. Any advice is appreciated
Old Dec 5, 2009 | 06:51 AM
TrueIce's Avatar
Default Re: 08 Civic Si Sedan Steering Problem
that can't be good.. do you have warranty?
Old Dec 5, 2009 | 10:20 AM
i-VTEC_DOHC's Avatar
well your brakes are worn unevenly. or else it wouldnt jerk.
as for your steering wheel, i cant help you there.
but im going to give the answer the rest of these people will say.
dealership.
Old Dec 6, 2009 | 12:05 PM
invsta's Avatar
Brakes. Not steering.
Old Dec 9, 2009 | 11:13 PM
08Si-R's Avatar
turns out the front passenger lower control arm had a bolt back all the way out of it where it attaches to the subframe. simple fix
Old Dec 10, 2009 | 04:22 AM
2008fijibluesi's Avatar
Did the dealership replace anything or did they just tighten it back up? If nothing was replaced, I'd check on the condition of the pieces involved. If it was driven on for some time with the bolt loose, it may have ovaled out the hole it was going into. Also, it could have damaged the threads of the bolt, weakening the hold of the threads and the bolt itself.
Old Dec 10, 2009 | 05:07 PM
TrueIce's Avatar
Very true..
Eee Kayyy
Apr 16, 2019 09:58 PM
buzlink
18
Nov 7, 2006 07:04 AM
looxs
Sep 16, 2005 08:19 PM
