Tri Y problems...
Old Dec 4, 2009 | 09:01 PM
93dxz6's Avatar
Default Tri Y problems...
I purchased a tri y header for my ls motor tonight...got it put on but for some reason the back of the header by the collector flange was angled toward the ground and not straight like my previous header?are ls heads different from a b16,gsr,or type r head?
Old Dec 4, 2009 | 09:21 PM
DDTECH's Avatar
Default Re: Tri Y problems...
tri y's do that sometimes..
my old hytech was like that.
Old Dec 4, 2009 | 09:25 PM
93dxz6's Avatar
got any ideas on how to fix it?cause with the angle its at theres no way its gonna bolt up to my exhaust..i thought about cutting at the weld where it starts to angle down and have a exhaust shop angle it up enough to make it staight.
Old Dec 5, 2009 | 12:35 AM
namewasdallas's Avatar
You got the idea bring ti to a muffler shop, another thing to do is get a flex pipe and attack it, or modifey your exhuast flange
Old Dec 5, 2009 | 04:20 AM
93dxz6's Avatar
i was gonna do some flex pipe but that still wouldnt fix the angle of the header it would eventually drag so much that the flange would be toast lol...guess i can just get it cut and angle it up more then re weld it..
Old Dec 5, 2009 | 07:31 AM
onefstek's Avatar
Was that a hytech or a replica?
You might want to reflect on that. Cuz I don't think a real hytech would have done that.
Old Dec 5, 2009 | 08:13 AM
93dxz6's Avatar
its a replica yes..only thing i know to do is cut it where it starts to angle and have it re-welded with it angled upright to make it even
Old Dec 5, 2009 | 09:52 AM
94civiccupew/b7's Avatar
i had the same problem with my header. what i did was, right after it collects to 2 pipes i cut a small v shape on the top. then torched the back side, got it cherry red, and bent it up to close the v cut. once you have it were u want it, have it welded up. worked for me
Old Dec 5, 2009 | 03:15 PM
killerpenguin21's Avatar
his was a true hytech.
Old Dec 5, 2009 | 03:34 PM
DDTECH's Avatar
Mine was a "real" hytech.. no knock off stuff.. Real custom made..
just the way the design is.
Old Dec 5, 2009 | 03:55 PM
stumpyf4's Avatar
Back off the screws that connect the 2 pieces together. If you tighten these screws too much the tail of the header will angle towards the ground.
Old Dec 5, 2009 | 09:29 PM
93dxz6's Avatar
ill try this out thanks for the info
Old Dec 5, 2009 | 10:39 PM
ef9civicgen4's Avatar
i did a "pie cut" on mine, about an inch after it merges into 2 tubes. rewelded it, and while i was at it, i welded all of the slip fit connections. fits perfect.
Old Dec 6, 2009 | 04:59 AM
93dxz6's Avatar
i also thought about welding where it slips together also,my buddies leaks around the two pipes that doesnt have the brackets/screws to draw it together
nyckid
10
Dec 22, 2015 09:04 AM
SR20S13
Welding / Fabrication
Mar 10, 2011 06:45 PM
ATS*Mark
Nov 25, 2005 01:31 PM
jdm_ef9
18
Apr 4, 2005 03:54 PM
bad-monkey
Oct 1, 2004 03:40 PM
