Suspension & Brakes Theory, alignment, spring rates....
help eibach & GC, what spring rate is this in lbs?
Old Dec 4, 2009 | 04:55 PM
egyolk's Avatar
Default help eibach & GC, what spring rate is this in lbs?
Hey there, already ran a search with no luck...
I picked up a set of GC's for my EF and on the springs it reads
180.64.44
and
180.64.61
i know that the last 2 digits represent the spring rates (44) (61) but what is it in lbs? i believe this is in newtons but i'm so confused because 1 newton is .2248 lbs? how would that work?!
Old Dec 4, 2009 | 05:05 PM
TunerN00b's Avatar
Default Re: help eibach & GC, what spring rate is this in lbs?
Spring rates aren't measured in weight (lbs), they're measured in force (lbs/in).
They're probably 44 and 61 N/m, in which case they would be 250 and 348 lbs/in springs.
And that conversion I got from the first result of a google search...
http://www.google.com/search?q=site%....com+180.64.44
Learning how to make the most of Google would be a good thing.
Old Dec 4, 2009 | 05:14 PM
STOCK_SOHC_DX's Avatar
180.64.44 = 7" x 2.5" x 250 lbs/ft
180.64.61 = 7" x 2.5" x 348 lbs/ft
Old Dec 4, 2009 | 05:17 PM
egyolk's Avatar
thank you guys, i just found that out myself too! i read a post from Tyson about the conversion of the units...
anyone know stock EF spring rates? the si trim hatch back? (not crx)
Old Dec 4, 2009 | 05:26 PM
I would run the stiffer in the front. Hope you have good shocks.
Old Dec 4, 2009 | 06:37 PM
egyolk's Avatar
Really? i'm not planning to have it dumped though, and i'm running sohc so no heavy dual cam...
I got these rates paired with koni yellows
Old Dec 4, 2009 | 06:38 PM
egyolk's Avatar
i'm just curious as to why you say that because a friend of mine will most likely tell me to stiffen the rear. any more insight is appreciated stock_sohc_dx
Old Dec 4, 2009 | 06:56 PM
Because of there is more weight in the front. It's more comfort @ these rates. If you wanted to stiffen up the rear I would run stiffer all the way around. 8k/6k or 10k/8k
Old Dec 5, 2009 | 04:44 PM
Tyson's Avatar
put the 350 up front first. thats the way it was designed. you dont seem like you need to be messing around with custom setups. but when you do, get stiffer rates to replace the rears from 250 to whatever.
250 up front is kinda low.
Old Dec 5, 2009 | 06:42 PM
egyolk's Avatar
I think there was a loss in translation or something!
the 350's are for the front
and the 250's were for the rear, I am curious though how much stiffer than stock it will feel. I was worried the rears would be a tad too soft. I have the koni yellows to compliment them
will be running 14x7 panasports with 195/60/14
can i just tune the shocks to be on the more firm side to dial in a more responsive feel in turn in?
Thanks! please feed me your knowledge Tyson!
Old Dec 5, 2009 | 06:44 PM
egyolk's Avatar
While turning is what i mean to say.. not "responsive feel in turn in?" or better yet through dips and imperfections in the road
Old Dec 5, 2009 | 07:59 PM
Tyson's Avatar
ive ridden in CRX's with koni GC regular springs. its fine. itll be much different than stock. work from there. adjust it the way you want it.
id focus on a rear swaybar next.
Old Dec 5, 2009 | 08:04 PM
egyolk's Avatar
Hey thanks Tyson, the only thing i worry about with stiff rears is snap over steer on these short wheel base cars.. I swung my type R sideways and its gone now.... I know now to keep on the throttle but once it was out, it was too late to push through.. is there anyway to avoid this
Old Dec 5, 2009 | 08:07 PM
Tyson's Avatar
dont drive like an idiot?
sorry if that sounds harsh. but theres no reason your rear end should come out if you drive within reason.
Old Dec 5, 2009 | 10:08 PM
egyolk's Avatar
no you're right, I already learned that the hard way
AlphaQup
Suspension & Brakes
11
Jun 22, 2008 04:09 PM
96 SOHC VTEC
Mar 30, 2003 10:17 AM
Superhatch
10
Feb 8, 2002 06:59 PM
B18CXr
Dec 12, 2001 12:59 PM
MrBite
Dec 9, 2001 09:09 AM
