BW S362 ett vs Precision 6262sp.... setup inside!
Old Dec 4, 2009 | 03:48 PM
2.0 and up's Avatar
Default BW S362 ett vs Precision 6262sp.... setup inside!
Finally its time to purchase my Turbo! I've been confused for a while and been doing a lot of research on both of these turbos! Since they are both almost equivalent at both price range and power. I wanted to know from you guys what you think and what will suit my needs better!
Here's my setup(will post pics soon)
Block;
b18b 83mm Golden eagle sleeved
89mm stock crank
9.1 cp pistons
eagle rods
Head;
stock port
skunk2 stg 1 cams
supertech valvetrain
edelbrock IM and sk2 70mm TB
1000 ID's
44mm WG
Hks BOV
2.5 charge piping
SLS turbo prototype manifold T3
I'am looking to pull anywhere from 500-600whp on 93 oct gas, car will be a daily driver!
Which one will suit my setup best for quicker spool and have a better powerband across on lower psi's? I know both of these turbos are fairly new, so any help is appreciated... Thanks in advanced
Old Dec 4, 2009 | 04:19 PM
reactiondc2's Avatar
Default Re: BW S362 ett vs Precision 6262sp.... setup inside!
considering the negative thread poppoing up about BE lately id go with the pte unit,besides alot of people have had excellent results with their line of billet wheel turbos
Old Dec 4, 2009 | 06:43 PM
Turbo-LS's Avatar
500-600 on pump gas huh?
Old Dec 4, 2009 | 06:47 PM
torres3030's Avatar
I have a car that was tune by fmfkid250 on a 6262 journal and it did 504whp at 20lbs on 93 octane at a conservative tune
Old Dec 4, 2009 | 06:53 PM
Turbo-LS's Avatar
I cant believe how much higher people are gettig out of pump gas, its crazy. i remember par for 93 octane was 400ish whp now peopel are really pushing it to the limits and make 500+. I just wouldnt chance it IMO not worth risking a very expensive engine over pump gas tuning to crazy hp numbers, im old skool i like the motto better safe than sorry LOL, but props to you guys doing it big on pump
Old Dec 4, 2009 | 07:50 PM
TheShodan's Avatar
Moderator
PTE has had its share of issues too. Not as much on this site, but its definitely present. What I'm trying to say is NO ONE IS IMMUNE
Old Dec 4, 2009 | 07:59 PM
boostedEF91's Avatar
can be done fairly easily..
Old Dec 4, 2009 | 08:26 PM
V-SPEC 1's Avatar
On Dynapak dyno for sure.
Old Dec 4, 2009 | 10:37 PM
2.0 and up's Avatar
how was the spool?
Ive even seen 1.8s making 500whp+ on pump gas!
Old Dec 5, 2009 | 05:22 AM
Silva Bullit DC4's Avatar
I've seen 500 and some change on 91 & 93 pump gas also, but 600 is a no-no IMO.
I'd say, stick with the lower end of your power goal if you are gonna be dedicated to pump gas only. Besides, 600 whp is practically useless (in certain ways) on the street for a daily driver anyway (even 500 for that matter, lol!), unless you're gonna double-duty it as a drag car also.
Old Dec 5, 2009 | 06:09 AM
Autoworks's Avatar
Quoted for the TRUTH.
I think the hp # on pump is a stretch, but I'm sure it could also be done. Either turbo is capable, it's going to boil down to persnal preference. I personally would use the S362. I've seen great results posted from both units.
Old Dec 5, 2009 | 08:48 AM
2.0 and up's Avatar
I guess your right, it comes down to personnal preference! ive read the 362 making up to 75whp over GT35Rs across in power! I wanted to know if the 6262 has similar characteristics and what are the lag differences betweeen the two.
Old Dec 5, 2009 | 10:40 AM
ScorpionT's Avatar
The 6262 will generally spool a touch quicker with the smaller turbine, but they should both make similar power overall when comparing the same boost.
Old Dec 5, 2009 | 04:11 PM
torres3030's Avatar
The spool is around 5700 rpm and is a GSR block bore to 81.5mm skunk2 stg1, edelbrock performer X manifold, .82 hotside and 10:1 comp. Dyno was done on a dynojet and for refrence AFR in the 11.3 to11.5 range.
Old Dec 5, 2009 | 09:17 PM
2.0 and up's Avatar
and this would be for the 6262?
Old Dec 5, 2009 | 09:29 PM
torres3030's Avatar
Yes and when I say spool I mean It's around 18lbs at that rpm.
Slowcrx360
Aug 21, 2014 08:02 AM
Samuels
Feb 21, 2009 09:12 PM
mikex1021
Aug 25, 2007 10:09 PM
Kid_SiR
Nov 20, 2006 05:38 AM
MR. BAR
Sep 8, 2005 09:33 PM
