New battery, good starter and alternator, but car won't start
Old Dec 4, 2009 | 03:33 PM
jsaye2002's Avatar
Default New battery, good starter and alternator, but car won't start
I have a 90 CRX and just did a tranny swap. My battery was dead after so I bought a new one, hooked it up and it won't start. It sounds like it wants to but just wont. I checked all the grounds and everything and those are all fine. What could the issue be? Its starting to get on my last nerves!
Old Dec 4, 2009 | 03:44 PM
4drEF's Avatar
Keyboard Humorist
Default Re: New battery, good starter and alternator, but car won't start
Are you getting spark?
Old Dec 4, 2009 | 03:48 PM
jsaye2002's Avatar
i can't tell
Old Dec 4, 2009 | 04:01 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Originally Posted by jsaye2002
i can't tell
LOL...
Well check it then...
Old Dec 4, 2009 | 04:06 PM
jsaye2002's Avatar
yeah i'm waiting for my friend to get over here so I can. But I don't see why I would just stop getting spark after a couple days of the car sitting. It was working fine before. But I'll check and see whats up
Old Dec 4, 2009 | 04:26 PM
W O T TWO's Avatar
Well obviously you have a problem, its not like the car "just sat" for a couple days, you did tranny service.
Old Dec 4, 2009 | 04:47 PM
jsaye2002's Avatar
well i'm aware but it started perfectly before. and the tranny is more of a mechanical thing as oppose to an electrical. everything that was unplugged to do the work is back on. Thats why I'm confused as to why it isn't starting even with a new battery. but if my laggin *** friend would get here i could check the plugs
Old Dec 4, 2009 | 04:50 PM
Marcos Barrios's Avatar
did you remember to connect the ground wire back on to your tranny?
Old Dec 4, 2009 | 04:56 PM
jsaye2002's Avatar
the one that hooks to the battery under the rack thing? yes i got it. unless there is just something i'm forgetting. but i've hooked up the starter, ground under the rack, the motor one on the right side
Old Dec 4, 2009 | 05:00 PM
blasterman87's Avatar
whats it doing? is it cranking or just click click
Old Dec 4, 2009 | 05:08 PM
jsaye2002's Avatar
its cranking. it was clicking but i put the ground on the starter better and it started cranking
Old Dec 4, 2009 | 05:27 PM
crx_si-r's Avatar
the ground connects to 2 spots. the transmission and the frame itself. are both connected. also check your ignition switch. and main fuse
Old Dec 6, 2009 | 10:03 PM
jsaye2002's Avatar
As retarded as I feel asking this, where is the mount thats on the tranny itself?
Old Dec 7, 2009 | 05:48 AM
hatchet_honda's Avatar
one on top and one on the front of the trans....did you unhook the ground wire on the thermostat housing? maybe to move the wire harness over a bit or somethin?
Old Dec 7, 2009 | 08:01 AM
4drEF's Avatar
Keyboard Humorist
Did you check for spark yet?
Old Dec 7, 2009 | 12:45 PM
jsaye2002's Avatar
yeah i have spark. haven't been able to get to it the last couple days cuz I've been outta town. I really think there is just something I forgot to hook up. And and i don't remember hookin anything up to a tranny ground so I'm gonna go look for that
Old Dec 7, 2009 | 01:10 PM
4drEF's Avatar
Keyboard Humorist
That ground goes from frame rail to the clutch cable bracket.
Old Dec 7, 2009 | 01:15 PM
jsaye2002's Avatar
Old Dec 7, 2009 | 01:18 PM
ghg78's Avatar
I NIKES
sounds like a ground unhooked.
Old Dec 7, 2009 | 01:50 PM
4drEF's Avatar
Keyboard Humorist
Odd that he's getting spark with a ground missing.
Figured you don't get spark or your starter doesn't crank when you miss a ground.
Old Dec 7, 2009 | 02:50 PM
ghg78's Avatar
I NIKES
Seen it happen on a few accords when the ground that hooks to the thermostat housing gets left unbolted.
Old Dec 7, 2009 | 03:51 PM
jsaye2002's Avatar
k everyone i got it....come to find out one of the wires hooked up to the dizzy wasn't all the way in lol. glad it was somethin simple
Old Dec 7, 2009 | 04:13 PM
csingham's Avatar
crazy mad murdock
nice catch
Old Dec 7, 2009 | 04:34 PM
KINGVEM^^ED6's Avatar
Glad u got it!
white-eg
Mar 18, 2010 08:17 PM
EGHondalover88
31
Jan 18, 2010 03:26 PM
lawlss
15
Sep 14, 2009 10:23 PM
sixfourkiller
Jun 17, 2009 10:05 AM
veilsides2000
Honda S2000
13
Apr 1, 2009 05:17 AM
