Suspension & Brakes Theory, alignment, spring rates....
what sway bar to go with 2000 civic ex
Old Dec 4, 2009 | 07:01 AM
2000EJ8's Avatar
Default what sway bar to go with 2000 civic ex
whats the best sway bar to run on a daily driven 2000 civic ex, with a stock front swaybar
Old Dec 4, 2009 | 09:23 AM
mkazm83's Avatar
Default Re: what sway bar to go with 2000 civic ex
99-2000 Si rear bar.
Old Dec 4, 2009 | 05:07 PM
STOCK_SOHC_DX's Avatar
+1 for this. Stock front might as well be stock back. Or if you can find that AEM optional I believe it was 15mm or 16mm that bolted directly to the subframe and not those tear out brackets.
Old Dec 4, 2009 | 09:44 PM
2000EJ8's Avatar
well i plan on adding an ASR bar to complete my Function 7 control arms. i love the *** end of my car so im gonna make it look even better. im on D2 coilovers and would like to do some spirited driving. i dont want to get too much oversteer though and definately dont want to lose the *** end of my car in a turn. would an SI bar still be the way to go?
Old Dec 4, 2009 | 10:51 PM
If your gonna add the ASR subframe brace might as well get a CTR sway. It might take a little getting used to. If you go with the Si bar I would tell you there is no need for the ASR but I have seen pics of EK's with stock bar subframe tear out(those guys must have rusted out subframe though).
Old Dec 5, 2009 | 08:30 PM
2000EJ8's Avatar
when you say a little getting used to, its because it will cause a little bit of oversteer with my stock front sway bar. isnt the CTR bar like a 21mm or something? what would be a good size for the front with a CTR bar to give it a neutral feeling, while eliminating most all body roll
Old Dec 6, 2009 | 08:26 PM
You pretty much hit the nail on the head. As for the front your stock one should suffice. You could go with the CTR bar in the front as well but for some reason I like a little more oversteer. I would try the CTR rear bar and then make your next move. If you already have your hands on the OEM Si bar try that first.
Old Dec 7, 2009 | 08:16 AM
2000EJ8's Avatar
i would like to try a CTR bar as everyone seems to agree its a pretty good choice once gotten used to......where could i find one with D-brackets?
theguy22
Suspension & Brakes
13
Aug 19, 2018 08:02 PM
RetroGamer
33
Aug 19, 2011 03:50 PM
2000EJ8
Suspension & Brakes
Apr 14, 2009 09:25 AM
chinkyx90
14
Feb 22, 2009 08:45 PM
Rouin
Honda Civic (2006 - 2015)
Mar 11, 2007 12:51 PM
