heater blows cold air
Old Dec 3, 2009 | 10:04 PM
Alucard1261's Avatar
New User
Default heater blows cold air
i dont know what is wroung with my heaterblows cold air blows. i put a new termostat in it and still no heat i did a coolint flush as well it fix the over heating prob but still no luck so if anyone know plz let me know
Old Dec 4, 2009 | 02:07 AM
supersize's Avatar
Default Re: heater blows cold air
check your blower motor. sometimes it takes a while for them to warm up.
Old Dec 4, 2009 | 06:12 AM
Former User's Avatar
Did you bleed the cooling system with the heat lever set to MAX heat? Is the heater hose valve on the firewall stuck closed?
Old Dec 4, 2009 | 06:13 AM
Dkober101's Avatar
bad heater coil?
Old Dec 4, 2009 | 10:27 AM
New User
how do you check to see if the firewall is stuck
Old Dec 4, 2009 | 12:11 PM
Corksil's Avatar
on the left side of the motor under the distributor there are two hoses that go towards the firewall. One of them is the feed and one is the return. One of them (feed) has a valve on it operated by a cable connected up under your dashboard to the heater control. You can either find the valve (not hard, it's obvious) or play with the hot/cold slider on the dash. If the slider slides from hot to cold super easy, the cable could be broken/disconnected - there should be a little bit of resistance as you slide the slider because it's moving the cable that opens the valve.
could also be not enough coolant in the system (open the bleeder valve by the thermostat when you fill the system, you know it's full when coolant starts coming out of the bleeder.) also put coolant in the reservoir, because even though it comes out the bleeder it might still suck some out of the reservoir after the motor runs a bit and the air bubbles work their way out.
prolly not the thermostat because you changed that...
could be plugged heater core, when you get it going make sure to run the heater (and a/c) every now and then all year to keep them working. The heater and a/c don't like only being used every 6 months, they seize up and stop working without regular use. Only takes a few minutes of use once a month to prevent this.
read my thread on this, it's almost the exact same problem...
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/car-overheats-heater-cold-thermostat-2690942/
good luck
Old Dec 4, 2009 | 12:48 PM
New User
https://honda-tech.com/forums/showthread.php?t=2690942
good luck
ya i found the cable you were talking about when i pull it just pulls is to the cold side and will not stay at the hot at all what is all sapose to be on that cable?? if you have txting tex me it cuse i really need to get this working asap 219 742 9549 thanks man
TaDLaD
Oct 1, 2009 11:31 AM
drm109
Aug 10, 2008 04:30 PM
BRAGAN
May 31, 2006 05:25 AM
cascaritas
17
Sep 22, 2004 06:50 PM
Conechaser
Oct 2, 2001 01:00 PM
