Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
a/c light on and tranny trouble?
Old Dec 3, 2009 | 08:29 PM
norcali707's Avatar
Default a/c light on and tranny trouble?
hello everyone....I just replaced the motor on my 2001 civic 1.7l and when I got it running, I noticed the a/c light is on when I have the fan on. I push the a/c bottom to turn it off but nothing happend....HELP?
ok the transmission trouble is that when I am going at high speed, I can heard a high pinch noise,like air leaking.....I check the fluid level and was pretty low, I put two quart of oil and I can still heard it but not as loud....can it be the tranny fluid still....thank you
Old Dec 4, 2009 | 03:24 AM
GriFFIthS's Avatar
Default Re: a/c light on and tranny trouble?
https://honda-tech.com/forums/showthread.php?t=2485503
Old Dec 6, 2009 | 05:48 PM
norcali707's Avatar
thank you for the link....it worked; however, I turn the a/c and looked at the a/c pump but didnt see the electronic pump clutch to kick in at all. this that normal? the tempeture outside is 40's.....I just want to make sure the a/c works....
Old Dec 7, 2009 | 05:31 AM
GriFFIthS's Avatar
Might have somthing wrong, Mine kicks in no matter the temp outside, example i used mine this morning to quickly defog the windows and its was -5C or 23F outside and it worked just fine.
Type_R_Lover
Jan 23, 2006 10:36 AM
revvin9k
Honda S2000
Oct 9, 2005 05:29 PM
ERIC!
Aug 16, 2005 11:22 PM
jdmsteve2004
May 24, 2004 08:29 AM
LSintegra
Apr 9, 2003 07:01 AM
