a/c light on and tranny trouble?
hello everyone....I just replaced the motor on my 2001 civic 1.7l and when I got it running, I noticed the a/c light is on when I have the fan on. I push the a/c bottom to turn it off but nothing happend....HELP?
ok the transmission trouble is that when I am going at high speed, I can heard a high pinch noise,like air leaking.....I check the fluid level and was pretty low, I put two quart of oil and I can still heard it but not as loud....can it be the tranny fluid still....thank you |
Re: a/c light on and tranny trouble?
thank you for the link....it worked; however, I turn the a/c and looked at the a/c pump but didnt see the electronic pump clutch to kick in at all. this that normal? the tempeture outside is 40's.....I just want to make sure the a/c works....
Might have somthing wrong, Mine kicks in no matter the temp outside, example i used mine this morning to quickly defog the windows and its was -5C or 23F outside and it worked just fine.
